    Just out of curiosity: Where is the color sample taken for a stroke?
    5 Posts 2 Posters 20 Views 2 Watching
      If I color multiple lines using the repeater.
      See pic.
        VectorStyler @Subpath
        @Subpath Are these repeated text frames?
          Subpath @VectorStyler
          my question has nothing to do with text frames
          the Text beside the stroke should only illustrate my question
          (made the text with inside of my screenshot app, is no vectorstyler text)
          on which point a stroke would take a color sample
          when using colorize with the repeater ?
          on top of the stroke, middle or end
          or elsewhere ?
            @Subpath Usually the color is sampled form the backdrop location at the center of the repeated object.
            Send me an example and I can tell more what happens in this case.
              I don't actually have a problem right now—perhaps I didn't explain it properly?
              Or maybe you misunderstood me for some reason.
              It’s just about a question:
              I was simply wondering at what point a stroke takes the color sample that then colors the stroke itself.
              Your answer regarding the center of the repeated object is fine enough for me.
              Thanks you.
