update 1.4.001
VectorStyler 1.4.001 release notes
- Added a new smooth curvature tool
- Added multiple new path brush tools
- Added margin constraint options to the Transform tool
- Erase using custom shapes
- Improved the Arc tool
- Added optical alignment options
- Added an optical snapping option to the snapping menu
- Position objects using their optical axes in the Transform panel
- Added Truchet tiling shape type and Truchet pattern presets
- Added a halftone type that uses Truchet patterns to simulate the backdrop
- Added a new Width Halftone shape using Truchet tiling shapes
- New repeater geometry mode (for Truchet tiles)
- New tiling pattern mode for more complex tiles (used for Truchet tiles)
- Added freeform gradients
- Action to remove opacity from objects inside selected groups
- Hierarchical object styling using groups and shapeless objects
- Added a document option for expanded stroke precision
- Allow pattern brushes to extend beyond the start and end of a path
- Show a curvature indicator while editing paths, using an option in the Path panel menu
- Added a node type that maintains G2 continuity
- Add curvature smoothing option to the pencil and path simplifying tools
- Select path nodes with G2 discontinuity
- Change path nodes to G2 continuity
- Select multiple consecutive nodes using Shift+Control
- Drag segments from interior points using Command (Control) key
- Move a node between its control points by holding Option (Alt)
- Scale selected control points around a common center by holding the Option (Alt) key
- Trace guide tool improvements
- Added a command to expand a clipped group into connected shapes (Extract Clipped Paths)
- Added an option to keep original shapes when combining (in Path panel menu Shape Combine Options)
- Divide shapes with open paths
- Added an option to Mirror and Transform groups to merge shapes when expanding
- Action to flatten curves to lines if they are almost flat
- Added a shape effect for smoothing curvature
- Combine multiple repeater geometry adjustments on a single repeater
- Option to place objects at segment centers in Along Path repeater mode
- Repeater colorizer option to align positions with region
- Proportional mode for repeater extent editing
- Action to rotate the view to the angle of the selection
- Added printing marks when exporting to PDF or PS
- Swap fill and stroke styles from the context panel
- Restrict font list to a specific script
- New command to apply the reverse of the last transform operation
- Create groups containing a single object to stack styles and effects
- Option to allow duplicate on other objects to repeat previous transform: Clear Transform on Selection in Other Options
- Overprint preview in both CPU and GPU views
Detailed list at: https://www.vectorstyler.com/documentation/introduction/newin_v1_4/
WOW !!!
This feels like a really big Christmas present—and sorry, but I’ll probably end up opening it before Christmas.
Once again, I am truly impressed!Thank you for your hard Work
Vectorstyler
Forgot, there is a minor thing.
During installation, VectorStyler displays version 1.3; the name of the icon is also 1.3.
But the installed App is 1.4 -
@Subpath said in update 1.4.001:
Thanks! Should be fixed now.
@VectorStyler This is really exciting! Thank you for all your hard work improving VS and doing so much extra behind the scenes to make the new 1.4 version so impressive! I am looking forward to checking out all of the new features and improvements. I prefer VS over any other vector editing software available today
