    Distributing nodes equally along a line.
    21 Posts 5 Posters 35.2k Views 1 Watching
    • G Offline
      Gremriel
      Hi,
      I saw this post on the Affinity forum today which looked interesting: https://forum.affinity.serif.com/index.php?/topic/122995-dividing-a-stroke-into-3-equal-lengths/&do=findComment&comment=672553
      So I thought I'd see if VS has the same option, but I couldn't get it to work, unfortunately. The tooltip for the distribute option mentions objects, so I guess it doesn't apply to nodes. Would love to see this functionality expanded to nodes as well (although it may be a niche case). Thoughts?
      WIndows 11
        VectorStyler @Gremriel
        @Gremriel I will check this, it might be a bug.
          For me it works. (VS, Win 10)
          Only at step 3 there was an unexpected flip of the line
          so I have to reverse it with a vertical flip.
            Subpath @Gremriel
            @Gremriel
            Even though the tooltip only says objects.
            In VS, you could use all the tools in the alignment
            panel for nodes as well.
            I know this possibility from CorelDraw and was delighted to
            find that in my attempts works also in VS. And I think VS does
            it even better than CorelDraw.
              VectorStyler @Subpath
              @Subpath I think the order in which the nodes were selected might matter here.
              S 2 Replies Last reply Reply Quote 1
                Subpath @VectorStyler
                Ah, ok. I have select them from left to right,
                as far as i know.
                  "...I think the order in which the nodes were selected might matter here...."
                  It doesn't seem to matter. Just tried it from right to left and vice versa and
                  get this unexpected Flip in both cases.
                  • G Offline
                    Gremriel
                    Node distribution
                    This is what happens for me. It seems the first couple of nodes seem to have an even spacing. but with the last step, the line flips.
                    WIndows 11
                      @Subpath OK, I open a bug on this one.
                        Subpath @Gremriel
                        @Gremriel
                        Hi
                        If the Line flip, you could still reflip it.
                        See in my steps i mentioned above.
                        And as I saw your video, the last segment of your Line seems to be
                        a curve. Change this segment, e.g. the whole line, to a "Straight Line"
                        first. Then the nodes should distribute properly.
                        • G Offline
                          Gremriel @Subpath
                          @Subpath whaddayknow.... I went to try again, and got the notification for an update. Installed that, and then it worked (albeit with the flip). Such customer support! 👌 ☺ (coincidence, I know ☺ )
                          The only thing I did different, though, was to click the straight line icon in the Path Panel, just to be sure.
                          WIndows 11
                          S G 2 Replies Last reply Reply Quote 0
                            Subpath @Gremriel
                            @Gremriel
                            Great that it works.
                            And, yes it seems it have to be a "Straight Line"
                            It's also a good day for me, the update fixed a bug I mentioned.
                            Have fun being creative 😉
                            • G Offline
                              Gremriel @Gremriel
                              @Gremriel Thanks 🙂
                              Just to be absolutely sure, I made one segment slightly curved, and although the nodes were distributed evenly, the operation kind of fails when the node that precedes the curved segment is not on the line anymore. But now I know what to look out for.
                              WIndows 11
                                Subpath @Gremriel
                                @Gremriel
                                yes, every Segment has to be a straight Line,
                                then it works. It did not work on Segments
                                which are curves.
                                  Boldline @Subpath
                                  @Subpath It would be cool if at some point, it would work on a curved segment as well
                                    Subpath @Boldline
                                    Got a kind of workaround for that.
                                    Its a function i know from CorelDraw and VS have this also.
                                    Take a look at the Picture here.
                                    The Nodes you set this way, will always be in the middle.
                                      @Subpath @Boldline @Gremriel The issue with distributing nodes has been identified. If any of the selected nodes has a control node (not the end of a line), the distribution may fail.
                                        Is this not also what I had written ?
                                        That all segments must be a "straight line"
                                        so that there are no control nodes in the line.
                                          @Subpath said in Distributing nodes equally along a line.:
                                          Yes, it is.
                                          • J Offline
                                            Jono
                                            Good tips. I learn so much from going through these bug reports as they often mention tools and techniques I've not even thought about yet! 👍
                                            Mac mini (M1, 2020) | Tahoe 26.1 | Wacom Cintiq 16 (1920 x 1080 px)
