    How do I reset panel default shape?
    3 Posts 3 Posters 4.3k Views 1 Watching
      How do I reset a panel's default shape (for lack of a better term)? I accidentally moved the strokes panel into the top section of VS and it conformed to that space and became wide. When I pulled it out of the top section, it retained that extreme width. Just closing it out and reopening the panel does not fix it.
        @Boldline If you dock it vertically it should revert to vertical layout. Then you can just undock it if you want it floating.
          @Boldline Drag the panel from the title area (that double horizontal line under the close button) to the right (or left) margin, where the blue highlight indicates docking.
