    Apply a pattern to a shape without the shape cutting off the edges of the pattern?
    16 Posts 6 Posters 14.6k Views 5 Watching
      fde101 Global Moderator
      Vectoraster can get very close to this. You can provide a custom SVG file for the shape the pattern is formed from, then use a raster export of whatever you want to apply the pattern to. The raster image serves to guide placement of the SVG "points" and the final results can be exported as fully vector in PDF, EPS or SVG.
        Hi, maybe a simple solution.
        But why don't create an array of your pattern, put it over
        the letters of the font and delete all the objects that overlap
        by hand ? So nothing is cut off like with the clipping mask.
        Here is an attempt of mine.
          By the way, there is a method in Inkscape to replace one
          object with another Object. Might be a little tedious though.
          But with this you can create a vector point array over your text
          in "Vectoraster" and later replace the points with the desired pattern
          you want in Inkscape? Doesn't seem sooo very practical, but possible.
          Here the Link to the Video:
          replace Objects in Inkscape
            Boldline @Subpath
            @Subpath thanks for the ideas and suggestions. I will try them out. I know I can find workarounds to get what I want and that will get me through for now. I'm hoping an option can be added in VS that allows for this like an internal command option to not cut off any part of the pattern that somehow touches a selected shape, etc.
              @Boldline It is doable with Repeaters. Still a bit slow, but it can be expanded once all attributes are set:
              0_1639482524952_pattern1.vstyler
                b77 @VectorStyler
                @vectoradmin Interesting! But I would disable font preview on the canvas with this — it froze the app here and I had to force-quit.
                encartE VectorStylerV 2 Replies Last reply Reply Quote 1
                  encart @b77
                  @b77 said in Apply a pattern to a shape without the shape cutting off the edges of the pattern?:
                  Same here.
                    encart
                    @Boldline Personally, I can see a lot of uses of Pixelate effects for images. It would be great if they had vector equivalents.
                    I used to play with these functions for a while. You can apply an effect and then try tracing. Unfortunately, I can't set up the tracing well in VS but I used then AI for tracing and the effect was pretty good.
                    https://recordit.co/kv5MwlHEck
                      VectorStyler @b77
                      @b77 Any specific steps on how to replicate the freeze?
                        b77 @VectorStyler
                        @vectoradmin Trying to change the font of the object at the bottom works the first or second time, then the app can freeze. I replicated the freeze but now when trying to record the screen it didn't freeze, but you can see that I have to wait for the app to catch up: https://recordit.co/QMbNX0ZOYW
                          VectorStyler @b77
                          @vectoradmin Trying to change the font of the object at the bottom works the first or second time, then the app can freeze. I replicated the freeze but now when trying to record the screen it didn't freeze, but you can see thatI I have to wait for the app to catch up: https://recordit.co/QMbNX0ZOYW
                          Yes, this one is very slow currently. I will try to find a way to make it faster.
                            Like the repeater.
                            Could not resist 🙂
                            Have use the File from vectoradmin.
                            To make this picture, i had to combine
                            three VS-Files for the Text.
                            But that the text remains editable, even
                            with this pattern on it, leaves me
                            speechless!
                            The Picture was build from
                            three Bitmap Files.
                              VectorStyler @b77
                              @b77 Repeater performance has improved in build 1.1.024
