    build 1.1.001 (beta)
    9 Posts 6 Posters 2.4k Views 5 Watching
      Some small fixes to the 1.1 beta are available:
      • Enable formulas in number editors.
      • Possible shape text scaling issues.
      • Offset path width profile is not visible in the profile drop down.
      • Transparency panel resizing.
      Update manually with Check For Updates,
      or form the releases page: https://www.vectorstyler.com/releaselog/
        Check update didn't work for me in the first 1.1 beta at all. I updated to 1.1 from 1.0 using it, so something must have happened in 1.1.
        EDIT: Updated manually from download page, 1.0.001 beta still throws this update error.
          fde101 Global Moderator
          I was able to update without issue.
          macOS 10.14.6
            VectorStyler @Ingolf
            @Ingolf Try again. Then problem was with the update feed on the server.
              Ingolf @VectorStyler
              @vectoradmin said in build 1.1.001 (beta):
              Fixed! "VectorStyler 1.1.001 is currently the newest version available."
                I was able to install it successfully without issues here
                • B Offline
                  B-Vs-V
                  Smooth manual update too (W10).
                  @vectoradmin I forget earlier to thank you for your presence on the forum and the follow-up you are willing to give to the various interventions and requests. This relationship is unique and shows that what we report can have some value and is not simply ignored (it is not always like that) 👍
                  S 1 Reply Last reply Reply Quote 5
                    Subpath @B-Vs-V
                    @PatrickM
                    agree 100%
                      like the option of incremental saving and that
                      you even thought of an option that automatically
                      creates folders for it.
