Add color to palette (fast) from color panel
Very common scenario here: I am satisfied with a color from my document - it is the active fill or stroke color - and I want to add it quickly to the palette. The add color implementation in VS probably assumes I already know the color from a Pantone swatch or some corporate identity manual but I am a creative hippie
that creates swatches on the go very often.
Affinity color panel menu:
What I am missing is the Add Color to Palette option in the color panel in VS.
@Ingolf Selecting 'New Color' from the Color Palette's menu should do that.
Same command works if you add it from the Color bar's menu. Or use 'Create from Selection'.But maybe 'Add Color to Palette' is better than 'New Color'?
@vectoradmin When doing this (adding new color to the Color Palette panel), the color is not added to the Color bar automatically.
@b77 Yes, Add is more meaningful because that is what it actually does.
I expected som "start from scratch dialog" workflow when I read New.
@vectoradmin Double click to edit fill and stroke in the palette panel would also be great.
@Ingolf This problem should be fixed in build 1.1.024
