    "Pucker and Bloat" equivalent in VS
    10 Posts 5 Posters 10.5k Views 3 Watching
      If I wanted to recreate this yellow diamond, how would I do so in VS? In Illustrator I would make a square and turn it on it's end and then use what they call "pucker and bloat" to suck in the sides. I was looking into options in documentation and probably missed it. I'm sure it already exists in VS!
      thanks!
      0_1643868219002_d486e9d7-003b-44ab-b2ab-79dc624361c7-BLD 2022-02-03 at 01.02.10.png
      VectorStylerV S 3 Replies Last reply Reply Quote 0
        @Boldline Distortion -> Circular Bump is the closest I can find, but it results in a different curvature of the sides.
        Also important to know: the sides of a rectangle (before convert to curve) can be bent using the Node tool.
          @vectoradmin Thanks - the distortion bump was pretty close. Is this something that could be added to the list for either improving the curve for or adding the pucker and bloat to VS in some other way? (not with that terrible name though!)
          The more I think of it - the distortion bump is already close - could another setting be added to that in order to set the curve more?
          0_1643873728528_426c490d-9c83-45c8-a9be-90b2a9c4681c-BLD 2022-02-03 at 02.34.53.png
            @Boldline The strength of the pucker effect control could be labelled... pucker factor? 😄
              Boldline @Ingolf
              @Ingolf pucker up or get bloated!
                Subpath @Boldline
                Sometimes I am also interested in
                which way may exist.
                After a few try´s, found a easy one in VS.
                Here the Video
                https://recordit.co/CTcKT3i59t
                W 1 Reply Last reply Reply Quote 4
                • W Offline
                  William Kansepa @Subpath
                  @Subpath Thank you for pointing this one out. But if I am not wrong, what @Boldline is advocating for is a pucker and bloat effect which would work on all kinds of shapes.
                    Subpath @William Kansepa
                    @William-Kansepa
                    yes, your right but in the meantime
                    this would help for those diamond shapes
                      Boldline @Subpath
                      @Subpath @William-Kansepa you're both right on this one.
                      That is a great solution @Subpath and @William-Kansepa, ideally @vectoradmin can add that pucker and bloat effect to Distortion -> Circular Bump so that it can be applied to any shape.
                      I appreciate all the suggestions - as @Ingolf might say, the pucker factor is strong with this one!
                        @Boldline In build 1.1.024: Node Bump shape filter.
