    Customizing context bar? ( accumulated )
    12 Posts 3 Posters 11.5k Views 2 Watching
      VectorStyler @Nils
      @Nils The upper row containing actions can be customized.
      The lower row (that is context sensitive) cannot, but it is already in the backlog as a feature request to be.
      • N Offline
        Nils @VectorStyler
        @vectoradmin After another look at the options I see how it works now. Both, the context bar under the application menu and the various context popups from right-clicking objects are considered contextual menus in this context, right?
        In this case, would it make sense to adjust the options ui to further distinguish between the contextual menus arising from the right-clicking and the one below the application menu?
          VectorStyler @Nils
          @Nils The right click contextual menus can be customized already (View -> Customize -> Contextual Menus).
          It is only the second row under the app menu that has an auto generated content for now. When this will be customizable, of course it will be possible to setup different content.
          • N Offline
            Nils @VectorStyler
            @vectoradmin Sry, I confused something. I thought the first bar below the application menu were somehow customizable, I mixed this up with the second one and the right-clicking menus...
            So since 1. is already in backlog, that leaves only 2. with the restrict button...
              VectorStyler @Nils
              @Nils Yes. Actually (2) is much easier to do, so probably will be available sooner 🙂
              • N Offline
                Nils @VectorStyler
                @vectoradmin Nice! That button is incredibly useful, basically takes tons off the cpu usage and visual clutter without taking away snapping capability.
                  VectorStyler @Nils
                  @Nils Build 1.1.024 contains an action (and it is in the tool bar also) to restrict snapping to the selected objects
                  • N Offline
                    Nils @VectorStyler
                    @vectoradmin Yes, I've noticed that. Great news. May I ask if you could do the same for the button, that clears the restrictions? I use these quite often.
                      VectorStyler @Nils
                      @Nils said in Customizing context bar?:
                      Restrictions can be cleared now by clearing the selection (click on an empty area) and then clicking the snapping restriction button.
                        @vectoradmin are we getting enough snapping options in the far upper right corner that it would make sense to organize them in a drop-down panel like the alignment currently is nearby?
                          @Boldline said in Customizing context bar?:
                          That already exists in the form of the Snapping panel. But I think in this case clearing restrictions could also be a ModifierKey+ click on the button?
