Can strokes with width adjustments be blended?
also on 26, win 10, Blend strokes working here
@Subpath you tried with the file I included?
no, made a similar Stroke like yours.
but will also try your file now, just a moment
@Subpath ok thanks - the reason I ask is because with those strokes, I had used the path width tool and that was where it seemed to give me issues trying to blend it properly afterward
first observation
the two strokes seems some how connected
if i hover over the left one both get selected- no regluar blend visible
as i copy and paste both the connection seems gone
also no regular blend, and if i expand the blend
i get only linesalso no regular blend i copy the your strokes to new file
Here the video
attemp with your file
in the video the left one is already blended
and expanded -
@Subpath said in Can strokes with width adjustments be blended?:
if i hover over the left one both get selectedThis is not happening with the strokes here - they are not grouped or connected
yes there is no group an i also found no combine
here is the video where i restarted VS
and only load your file, seems sometimes
connected and other not
just your file -
@Subpath thanks for checking that - it may just be an odd obscure situation that @vectoradmin can figure out why it is occurring that way..
@Subpath They are connected because they form a blend object already. But since they are so close to each other, the first object is more difficult to select separately (hover the cursor on its left and click).
@Boldline Indeed this seems to be a bug — if you get rid of the brush contour of both red lines the interpolation works.
ah, interesting good to know
but curious -
@Boldline I think the issue is that these two shapes contain brushes, and it seems that the brush content is not blended.
