    How do I selectively edit the height of some of the text on a path?
    9 Posts 4 Posters 8.5k Views 3 Watching
      Does anyone have any suggestions for how I could increase the height of the middle section of letters in the "Halter & Horses" Ideally I'd like to shrink the ends some and raise the height of the center
      0_1648824845625_1d4ac86b-1aee-455e-99fe-00d09ebcedbf-BLD 2022-04-01 at 10.49.36.png
      b77B VectorStylerV S 4 Replies Last reply Reply Quote 0
      • b77B Offline
        b77 @Boldline
        @Boldline That's how I would do it:
        After placing the text on a path, I would convert it to curves then apply a Bulge Warp* effect and drag the middle handles to make it taller in the middle.
        *not Squeeze like I wrote the first time.
          @Boldline Another way: instead of text on path, use the Bend distortion with variable width profile.
          And then enable the rigid shapes option for the Bend effect.
          EDIT: this will rotate the letters, so probably not going to work.
          • b77B Offline
            b77 @VectorStyler
            @vectoradmin Your approach would be better than mine because it keeps text editable, but how do you get rid of the rotation of the letters?
              VectorStyler @b77
              @b77 said in How do I selectively edit the height of some of the text on a path?:
              @vectoradmin but how do you get rid of the rotation of the letters?
              You cannot, I missed that part.
              • b77B Offline
                b77 @VectorStyler
                @vectoradmin Got it. To be used only with italics then. 🙂
                  Subpath @Boldline
                  @Boldline
                  As a simple Solution you could also give each Letter
                  in this line a different Size.
                  Or you can also use separate letters with different sizes.
                  Video
                  Each letter a different size
                  • b77B Offline
                    b77 @Boldline
                    @Boldline and @Subpath
                    I tested all this again and converting the text to curves is not needed — as long as you select both the text and the path, the Bulge effect (or any other Warp) is assigned correctly.
                    @vectoradmin In my opinion, any shape effect should apply to the entire object, even if you selected just the text.
                    Only if you selected the path it should apply the effect to the path separately.
                      Subpath @b77
                      @b77
                      .... converting the text to curves is not needed ...
                      Thanks, I already know that. Have been experimenting around with Envelope Shape and others lately.
                      Will post the findings in the tutorial or general section (not sure where yet) in the near future.
                      but could possibly be better in some circumstances for a smoother shape/curve progression
