Inspiration - less busy interface in Gravit Designer Pro
  • Inspiration - not a request - almost 🙂
    Some months ago the layers panel was much improved usability-wise. I think it can be improved further even though I am satisfied now. Or as the main character says in Transpotting - "For the first time in my adult life I was almost content." 🙂
    From time to time I use Gravit Designer Pro (runs from the browser) because it is pleasant to work in. The interface is kept simple and I especially like the layers panel.
    Serif and Adobe tried to reduce visual noise in their layers panel by moving the lock icon to the top of the layers panel and the reception was and is not great. Both kept the "Visible" checker to the left or right of each layer though. The solution to added complexity is to make icons and control elements tiny. Then some users need glasses or to configure them... bigger. Back to square one.
    If you rarely hide anything (or lock it) all these icons are just noise. In many programs - VS included - both the lock and visibility icon are visible:
    In this case the selected on canvas icon drowns in the mess. And it is important. If image and shape effects are added to the layer in total 5 icons are displayed. Imagine a layers panel with many of these effects used. Busy interface.
    Gravit Designer solved it elegantly by hiding the lock and visibility icons when they are not in use - but shoving them when the users hovers the pointer above them. When a layer is locked or hidden, the corresponding icon is displayed.
    If the feature panel in VS worked the same way (but always displays the selected on canvas circle icon) the layers panel would be a more pleasant experience - and more user friendly (which in fact translates to 'more usable').
    Notice how much it distracts they eye and mind when I activate all icons and how much it helps when I deactivate them again.
    alt text
  • To visualize the difference:
    0_1650750735960_Skærmbillede 2022-04-23 kl. 23.27.04.png 0_1650750766451_4198fe38-5cd3-4659-a145-8f122fbe583f-image.png
  • @Ingolf Interesting idea.
    I'm not sure about the part where Gravit displays these two icons only when you hover the right side of the layer?
    If this gets implemented (option in Prefs?) I see no reason to not have these displayed when you hover the layer anywhere.
  • @b77 said in Inspiration - less busy interface in Gravit Designer Pro:
    Hovering above whatever part of the layer displays these icons. It is impossible not to discover them and understand how it works. 🙂
    alt text
    I do not think it should be an option in preferences. The author of a a program should sometimes stand by more basic design decisions. Preferences are so packed with options that it is almost counter productive. Making whatever optional also adds code and complexity to the program. More code to maintain, more risk of regressions and more complexity overall in the product. And we can still count the number of developers with one finger. 🙂
  • Hovering above whatever part of the layer displays these icons. It is impossible not to discover them and understand how it works. 🙂
    Yes, I wasn’t sure it does that.
    Then it sounds good to me.👌
  • @Ingolf I thought about the second part in your last reply (hiding these buttons by default, with no Prefs option), and I’m not sure everyone would be OK with having to move the cursor over the Layers panel to see what’s locked or hidden and what’s not, especially on big screens and maybe tablets.
    Other users care to chime in about this?
    Btw, let’s not forget the approach where only the current layer is active and objects on all other layers are selectable with Cmd/Ctrl-click. This would make locking layers unnecessary most of the time.
    I hope this will become an option in the future, even the default one. 🙂
  • @Ingolf I like the idea of only seeing the icons when you over (deactivated) or visible when activated.
    Another possible idea is the way Blender handles it. The user can check and uncheck the options they wish to have visible allowing complete configurability.
  • @Victor-Vector said in Inspiration - less busy interface in Gravit Designer Pro:
    Interesting but in Blender the interface is extremely busy everywhere so I understand they make it optional to see this and that whereever they can. In the layers panel they show 5 icons and in a worst case 7. With the filter they are trying to put out a usability fire. 🙂
    In Vectorstyler the interface is generally pretty clean (except for the too many combine icons) and in the case of Vectorstyler I think the most elegant and user friendly method would be to just hide them like in Gravit. I think it would also work in Blender.
    I would make more sense to me to have them be a faded shade of gray so they are still somewhat visible and can be clicked on - any that are active stay lit up
  • @Boldline said in Inspiration - less busy interface in Gravit Designer Pro:
    Not to me. I know they are there after hovering them a few times. After hovering them a billion times even more so. 🙂
  • @Ingolf said in [Inspiration - less busy interface in Gravit Designer Pro]
    I disagree, I think filters are a perfectly viable way to handle this particular interface situation that you have an issue with. I think your proposal is just another way of doing it. Like I said, I don't mind if they are hidden, or less visible, or of there are filters. They are all good options.
    Yeah, but if you take a close look, filters are often introduced when the interface gets complex and it is best to avoid that scenario alltogther if at all possible.
