<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Playing with Blend in Pattern Brush]]></title><description><![CDATA[<p dir="auto"><img src="/forum/assets/uploads/files/1654622376516-pattern-brush-40.png" alt="0_1654622336586_Pattern-Brush-40.png" class=" img-fluid img-markdown" /><br />
.<br />
<strong>Table of content</strong><br />
.<br />
<strong>1. Post -- is below here<br />
Using Blends, Multiblends and Variations</strong><br />
.<br />
<strong>2. Post</strong><br />
<a href="https://www.vectorstyler.com/forum/topic/2089/playing-with-blend-in-pattern-brush/8"><strong>Tip -- Even distributed shapes between decreasing Pattern Shapes</strong></a><br />
.<br />
<strong>3. Post</strong><br />
<a href="https://www.vectorstyler.com/forum/topic/2089/playing-with-blend-in-pattern-brush/9"><strong>Tip -- Combining Pattern Brushes and combining rigid and non rigid Pattern Brushes</strong></a><br />
.<br />
.<br />
Hi</p>
<p dir="auto">Back to play again in VS <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=ec4d969cc53" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
<p dir="auto">This time with:<br />
The Pattern Brush and - Blend object inside pattern and other brush types -<br />
( a new functionality in VS since Version 1.0.42 )<br />
.<br />
.<br />
Whats to see?<br />
-- Multi Blends in VS with the Blend Tool<br />
-- some Tricks / Ideas<br />
-- using of Style Picker in conjunction with a Pattern Brush<br />
.<br />
.<br />
A few Notes beforehand:<br />
This is not a tutorial, I'm just showing some finds/ideas and tricks<br />
I noticed while playing with the Pattern Brush since version 1.1.042<br />
despite that I kept it in some order<br />
.<br />
The new functionality may not be helpful in any case because<br />
it sometimes creates artifacts.<br />
.<br />
While i play with different Designs i found out that those Pattern<br />
often have a few sweet spots and some Pattern Brushes dont<br />
work on any Shape.<br />
.<br />
Round Corners work better then sharp Edges. Bigger Shapes<br />
better then small ones and tight curves could cause Problems.<br />
So, from Shape to Shape you have to find some workarounds<br />
to get the Results you after.</p>
<p dir="auto">But anyway all this is still better then to live without that Pattern Brush feature.<br />
I nevertheless have fun with it and am glad about this new option <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=ec4d969cc53" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /><br />
.<br />
.<br />
Here we go:</p>
<p dir="auto"><img src="/forum/assets/uploads/files/1654622780541-blend-1.png" alt="0_1654622740924_Blend-1.png" class=" img-fluid img-markdown" /><br />
To create a Blend select two shapes, Blend and Group them (Blend Tool (W) )<br />
.<br />
To create a Pattern Brush with it, select your grouped Blend<br />
go to Menu Styles -&gt; Create Styles -&gt; Create Pattern Brush Preset<br />
.<br />
.<br />
<img src="/forum/assets/uploads/files/1654622891728-blend-2.png" alt="0_1654622852080_Blend-2.png" class=" img-fluid img-markdown" /><br />
Then choose the Brush Tool (B) select your Pattern Brush and paint.<br />
.<br />
If you dont want any Pattern Deformation, choose "rigid shapes" and<br />
"scale rigid shapes" in Pattern Brush Option Menu.<br />
.<br />
.<br />
<img src="/forum/assets/uploads/files/1654622929434-blend-3.png" alt="0_1654622890118_Blend-3.png" class=" img-fluid img-markdown" /><br />
If you dont want those repeatings, create longer Blends (e.g. a longer Pattern)<br />
.<br />
.<br />
.<br />
<img src="/forum/assets/uploads/files/1654623011442-multi-blend-1.png" alt="0_1654622971816_Multi-Blend-1.png" class=" img-fluid img-markdown" /><br />
For those who do not know it yet: Multiblends are also possible.<br />
Select the first two shapes, create a blend. Then select the last shape<br />
of this blend and the new shape and so on...<br />
.<br />
The sad news are, this would give you no continues Curve<br />
.</p>
<p dir="auto"><img src="/forum/assets/uploads/files/1654623071425-multi-blend-2.png" alt="0_1654623032104_Multi-Blend-2.png" class=" img-fluid img-markdown" /><br />
The good News are, if you create a pattern brush with your Blend<br />
that give you that continues Curve now<br />
.<br />
.<br />
.<br />
Multiblends don't necessarily have to be created with the last shape.<br />
You can be creative and mix them according to your taste</p>
<p dir="auto"><img src="/forum/assets/uploads/files/1654623177756-multi-blend-3.png" alt="0_1654623138105_Multi-Blend-3.png" class=" img-fluid img-markdown" /><br />
These are 4 individual blends, which was then grouped together<br />
.<br />
<img src="/forum/assets/uploads/files/1654623222417-multi-blend-4.png" alt="0_1654623183097_Multi-Blend-4.png" class=" img-fluid img-markdown" /><br />
.<br />
.<br />
<img src="/forum/assets/uploads/files/1654623239079-multi-blend-5.png" alt="0_1654623199761_Multi-Blend-5.png" class=" img-fluid img-markdown" /><br />
.<br />
But remember to play with the Settings/Shape size to avoid Artefacts<br />
.<br />
.</p>
]]></description><link>https://www.vectorstyler.com/forum/topic/2089/playing-with-blend-in-pattern-brush</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Jul 2026 00:22:12 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/2089.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 07 Jun 2022 17:24:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Playing with Blend in Pattern Brush on Thu, 24 Nov 2022 16:01:12 GMT]]></title><description><![CDATA[<p dir="auto">@Pat said in <a href="/forum/post/16145">Playing with Blend in Pattern Brush</a>:</p>
<p dir="auto">Thank you</p>
<blockquote>
<p dir="auto">I should have read this before starting the blending thread</p>
</blockquote>
<p dir="auto">... not really necessary, I like your own view</p>
]]></description><link>https://www.vectorstyler.com/forum/post/16147</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/16147</guid><dc:creator><![CDATA[Subpath]]></dc:creator><pubDate>Thu, 24 Nov 2022 16:01:12 GMT</pubDate></item><item><title><![CDATA[Reply to Playing with Blend in Pattern Brush on Thu, 24 Nov 2022 15:10:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/subpath" aria-label="Profile: Subpath">@<bdi>Subpath</bdi></a> Well done <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f44d.png?v=ec4d969cc53" class="not-responsive emoji emoji-android emoji--+1" style="height:23px;width:auto;vertical-align:middle" title=":+1:" alt="👍" /></p>
<p dir="auto">I should have read this before starting the blending thread...  well, too late <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/263a.png?v=ec4d969cc53" class="not-responsive emoji emoji-android emoji--relaxed" style="height:23px;width:auto;vertical-align:middle" title=":relaxed:" alt="☺" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/16145</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/16145</guid><dc:creator><![CDATA[B-Vs-V]]></dc:creator><pubDate>Thu, 24 Nov 2022 15:10:17 GMT</pubDate></item><item><title><![CDATA[Reply to Playing with Blend in Pattern Brush on Mon, 13 Jun 2022 09:59:03 GMT]]></title><description><![CDATA[<p dir="auto"><strong>Combining Pattern and combining rigid and non rigid Pattern Brushes</strong><br />
.<br />
.<br />
Sometimes it doesnt work to set the shapes in your pattern brush<br />
to rigid or non-rigid. As it will not cover all needs of your Pattern.</p>
<p dir="auto">Like this example show:<br />
<img src="/forum/assets/uploads/files/1655109335343-pattern-brush-4.png" alt="0_1655109291949_Pattern-Brush-4.png" class=" img-fluid img-markdown" /><br />
.<br />
.<br />
The solution is a simple practical one:<br />
Create two Pattern, set one Part to rigid and the other Part not<br />
and place one Pattern on top of the other.<br />
.<br />
Copy your Shape and apply the first pattern onto<br />
the one shape and your second pattern onto the copy.<br />
.<br />
Select both, use Alignment panel, click on horizontal center<br />
and vertical center and you have a much nicer result than before.<br />
( is also possible to record a Action with the Alignment Steps,<br />
so its just one click then)<br />
.<br />
Found this a nice way to combine several different pattern brushes.<br />
E.g. creating pattern for inner and outline structures.<br />
.<br />
.<br />
Here some Example Pictures:<br />
.<br />
<img src="/forum/assets/uploads/files/1655109538247-pattern-brush-2.png" alt="0_1655109495245_Pattern Brush-2.png" class=" img-fluid img-markdown" /><br />
.<br />
<img src="/forum/assets/uploads/files/1655109547532-pattern-brush-2a.png" alt="0_1655109504843_Pattern Brush-2a.png" class=" img-fluid img-markdown" /><br />
.<br />
<img src="/forum/assets/uploads/files/1655109560696-pattern-brush-2c.png" alt="0_1655109518008_Pattern Brush-2c.png" class=" img-fluid img-markdown" /><br />
.<br />
<img src="/forum/assets/uploads/files/1655114335231-pattern-brush-2d.png" alt="0_1655114292306_Pattern Brush-2d.png" class=" img-fluid img-markdown" /><br />
.<br />
.<br />
<img src="/forum/assets/uploads/files/1655109584661-pattern-brush-3.png" alt="0_1655109541979_Pattern Brush-3.png" class=" img-fluid img-markdown" /><br />
.<br />
<img src="/forum/assets/uploads/files/1655109899889-pattern-brush-3a.png" alt="0_1655109857030_Pattern Brush-3a.png" class=" img-fluid img-markdown" /><br />
.<br />
.<br />
<img src="/forum/assets/uploads/files/1655109608819-pattern-brush-1a.png" alt="0_1655109566122_Pattern-Brush-1a.png" class=" img-fluid img-markdown" /><br />
3 Pattern Brushes used<br />
.<br />
<img src="/forum/assets/uploads/files/1655109615854-pattern-brush-1.png" alt="0_1655109572858_Pattern-Brush-1.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/11702</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/11702</guid><dc:creator><![CDATA[Subpath]]></dc:creator><pubDate>Mon, 13 Jun 2022 09:59:03 GMT</pubDate></item><item><title><![CDATA[Reply to Playing with Blend in Pattern Brush on Fri, 29 Mar 2024 06:59:37 GMT]]></title><description><![CDATA[<p dir="auto"><strong>How to get better even spacing in such patterns</strong><br />
<img src="/forum/assets/uploads/files/1654674465895-even-space-2.png" alt="0_1654674426545_Even-Space-2.png" class=" img-fluid img-markdown" /><br />
.<br />
.<br />
<img src="/forum/assets/uploads/files/1654674566886-even-space-1.png" alt="0_1654674527211_Even-Space-1.png" class=" img-fluid img-markdown" /><br />
Even spacing between the shapes is easy with such patterns<br />
.<br />
.<br />
<img src="/forum/assets/uploads/files/1654674610643-even-space-2.png" alt="0_1654674571295_Even-Space-2.png" class=" img-fluid img-markdown" /><br />
But seems not possible when using Profils<br />
.<br />
.<br />
<img src="/forum/assets/uploads/files/1654674670245-even-space-3.png" alt="0_1654674630901_Even-Space-3.png" class=" img-fluid img-markdown" /><br />
Using Blend gives us the option to adjust the space with "Position"<br />
in Blend Option. But I am not really happy with this way.<br />
.<br />
.<br />
.<br />
I like to use the Alignment Panel and the Align to Shape "...distribute equal distances..." icon.<br />
.<br />
Here how to do it:<br />
Create a Blend with your Pattern.<br />
( Transformation with copy would also work, I find a Blend easier )<br />
Expand the Blend and Ungroup it and draw a straight Line below.<br />
<img src="/forum/assets/uploads/files/1654675049861-even-space-blend-4.png" alt="0_1654675010192_Even-Space-blend-4.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">.<br />
.<br />
<img src="/forum/assets/uploads/files/1654675244888-even-space-blend-5.png" alt="0_1654675205212_Even-Space-blend-5.png" class=" img-fluid img-markdown" /><br />
Select all shapes of the pattern. Hold the Shift-Key and select the straight line.<br />
Call the Alignment Panel. In the Align Panel Menu, select Geometric Alignment<br />
and then the &gt; Align to Shape "...distribute equal distances..." Icon.<br />
<img src="/forum/assets/uploads/files/1654676995330-alignment-distance-1.png" alt="0_1654676955645_Alignment-Distance-1.png" class=" img-fluid img-markdown" /><br />
.<br />
.<br />
<a href="https://go.screenpal.com/watch/cZeU1PV7Sto" rel="nofollow ugc">Here a Video, how to do it, re-upload:</a><br />
.<br />
.<br />
Delete the Line and Group the Result an create a Pattern Brush Preset with it.<br />
Set "Rigid shapes" and "Scale rigid shapes".<br />
.<br />
.<br />
<img src="/forum/assets/uploads/files/1654675633804-even-space-blend-6.png" alt="0_1654675594134_Even-Space-blend-6.png" class=" img-fluid img-markdown" /><br />
To control the space between the Shapes in this Pattern Brush,<br />
play with the Line length and with the Node Handles<br />
.<br />
.<br />
<img src="/forum/assets/uploads/files/1654675656194-augen-60.png" alt="0_1654675616823_Augen-60.png" class=" img-fluid img-markdown" /><br />
.<br />
.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/11617</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/11617</guid><dc:creator><![CDATA[Subpath]]></dc:creator><pubDate>Fri, 29 Mar 2024 06:59:37 GMT</pubDate></item><item><title><![CDATA[Reply to Playing with Blend in Pattern Brush on Wed, 08 Jun 2022 08:22:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/encart" aria-label="Profile: encart">@<bdi>encart</bdi></a></p>
<p dir="auto">I think this is a result of which way, right or left, you create a shape.<br />
Then the starting/connecting points are probably different.</p>
<p dir="auto">But as <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/b77" aria-label="Profile: b77">@<bdi>b77</bdi></a> said flipping or rotate the start or end shape<br />
will fix that</p>
]]></description><link>https://www.vectorstyler.com/forum/post/11603</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/11603</guid><dc:creator><![CDATA[Subpath]]></dc:creator><pubDate>Wed, 08 Jun 2022 08:22:51 GMT</pubDate></item><item><title><![CDATA[Reply to Playing with Blend in Pattern Brush on Tue, 07 Jun 2022 19:57:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/b77" aria-label="Profile: b77">@<bdi>b77</bdi></a> Thanks! Flipping solved the problem.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/11595</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/11595</guid><dc:creator><![CDATA[encart]]></dc:creator><pubDate>Tue, 07 Jun 2022 19:57:59 GMT</pubDate></item><item><title><![CDATA[Reply to Playing with Blend in Pattern Brush on Tue, 07 Jun 2022 19:55:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/encart" aria-label="Profile: encart">@<bdi>encart</bdi></a> Maybe you need to flip and also rotate one of the shapes.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/11594</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/11594</guid><dc:creator><![CDATA[b77]]></dc:creator><pubDate>Tue, 07 Jun 2022 19:55:43 GMT</pubDate></item><item><title><![CDATA[Reply to Playing with Blend in Pattern Brush on Tue, 07 Jun 2022 19:52:58 GMT]]></title><description><![CDATA[<p dir="auto">My playing ended in the first stage. Unfortunately I am getting a strange transformation when applying the blend effect. Mapping does not help<br />
<img src="/forum/assets/uploads/files/1654631406067-screenshot_20220607_214801-resized.png" alt="0_1654631405658_screenshot_20220607_214801.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/11593</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/11593</guid><dc:creator><![CDATA[encart]]></dc:creator><pubDate>Tue, 07 Jun 2022 19:52:58 GMT</pubDate></item><item><title><![CDATA[Reply to Playing with Blend in Pattern Brush on Tue, 07 Jun 2022 19:46:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ingolf" aria-label="Profile: Ingolf">@<bdi>Ingolf</bdi></a><br />
]]></description><link>https://www.vectorstyler.com/forum/post/11592</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/11592</guid><dc:creator><![CDATA[Subpath]]></dc:creator><pubDate>Tue, 07 Jun 2022 19:46:44 GMT</pubDate></item><item><title><![CDATA[Reply to Playing with Blend in Pattern Brush on Tue, 07 Jun 2022 19:08:56 GMT]]></title><description><![CDATA[<p dir="auto">Whow, I have to play with that soon! <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f61b.png?v=ec4d969cc53" class="not-responsive emoji emoji-android emoji--stuck_out_tongue" style="height:23px;width:auto;vertical-align:middle" title=":-p" alt="😛" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/11588</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/11588</guid><dc:creator><![CDATA[Ingolf]]></dc:creator><pubDate>Tue, 07 Jun 2022 19:08:56 GMT</pubDate></item></channel></rss>
