update 1.1.058
VectorStyler 1.1.058 release notes
- Mesh gradient rendering smoothness with complex shapes.
- Display of rotated images with large zoom.
- Allow overwriting numeric keys with shortcuts when opacity input is enabled.
- Allow opacity value input with numeric keys on Windows.
- Randomize stroke width profile preview did not work.
- Allow stroke width increase in stroke width profile adjustments.
- Active palette indication in palette panel menu.
- Possible crash when previewing stroke width profile.
- Regression in selecting the last gradient node when the tool is activated.
- Isolate symbols for editing with double click or Layers panel menu.
- Faster bitmap displays in wire frame mode.
- Entering new line into text resulted in extra new line on Windows.
- Deleting in number fields should leave it empty.
- Editing color style may erase the style name.
- Shortcut customization list column widths to fit into available space.
- Panel preview in hidden layers and objects did not show objects correctly.
- Bevel image effect rendering.
- Editing gradient shapes.
- Create blend between symbol instances.
- Allow anchored blend and text on path inside symbols.
- Possible crash in pattern brush with small tiles.
- Selecting shapes for text on path input in text editors.
- General stability improvements.
@VectorStyler said in update 1.1.058:
Confirmed major increase in speed in preview mode !
Thanks for that !
Neil
Looks great now!
Bevel looks better but the display quality
of the Outline isnt good, no antialiasing
even to set the Subpixel to 24x24 doesnt helpsee pic, both shape are identical
but the right one got the bevel on it
and a minor thing
some deforming happens, sometimes more
sometimes less, if you leave the Canvas
with a beveled shapehere a video example
link textsee Video
it did work now, but no live preview
you have to turn the preview off and on again
to see the changes -
could you explain where and how this work ???
could not find it out -
@Subpath in the "Adjust Width Profile" view -> "Scale Width" field.
thank you, i think i got it now
Stroke With Panel > Adjust Profil with Mask > Scale With Field
in the upper right -
"Adjust Profile with Mask"
works pretty well now
