Can the history panel be paused?
  • if I make a new VS file and set the history to record and then later go into the document preferences and turn off the history record option, will it continue to record anyway? When i did this, the history panel continued to record anyway.
    @Boldline If turned off, the history will be still recorded because it is needed for undo / redo, but it will not save it into the file when the document is saved.
    Besides disabling the store option, also reduce the "History Limit" field to 1, to reduce how much history is recorded.
