    update 1.1.062
    10 Posts 4 Posters 2.1k Views 3 Watching
      VectorStyler 1.1.062 release notes
      Improvements
      • Option for cross hair cursor Show Crosshair Cursor in Preferences -> Performance section.
      • Add color merge command to the palette panel.
      • Show transform selection after drawing shapes.
      • Single objects should be aligned to page when alignment command is used.
      • Select GPU in preferences on multiple GPU systems.
      • Option (Preferences -> Changing Options -> Select After Delete) to select a sibling object when the selected objects are deleted.
      • Added blend mode selection to the image effect transparency.
      • Improved Preferences view layout.
      • Added Trim to Artboard option to Rasterize command.
      • Improved the polygonal lasso tool.
      Fixes
      • Replace colors with global or spot colors when adding to palette from selected objects.
      • Saving artboard options presets should include margins and guidelines.
      • Fixed left and right mouse button use in color palette bar (regardless of active color target selection in the color panel).
      • Using shape distortion effects on images to have a better sampling resolution.
      • Fixed multiple bugs in toolbox and menu customization.
      • Flip horizontal and vertical to use center pivot by default.
      • Point and shape snapping to always enter into groups.
      • Cursor position in ligatures.
      • Correct transform pivot when transforming node selections.
      • New layer name to be used correctly when creating new layer with the menu command.
      • Correct polygonal spiral location when creating the shape using a single click.
      • Single node selection left after deleting a node.
      • Possible crash when using styles for shape filters.
      • Improved Illustrator file format importing.
      • Removing stray segments in shapes to set correct corner types.
      • Using shortcuts on Windows while the text editor is active.
      • Increasing stroke width using keyboard to start from 1 pt.
      • Rendering inner or outer aligned stroke on styled text.
      • Ruler selection indicator is not shown correctly for top down coordinates.
      • Levels image effect to show options correctly in the modal view.
      • Editing image effects in the modal view accessed from the layers panel, adding the second effect.
      • Show the None label in the stroke width editor when the object has no stroke.
      • Layers panel cannot remove object selection when the node tool is used.
      • Do not show the document options buttons while using the pencil and pen tools.
      • Better brush tip icon for the eraser tool.
      • Undo shape pasting to restore shape effects also.
      • Jumping to first artboard when entering or leaving isolated mode and other cases.
      • Better names for duplicated artboards.
      • Fixed bugs in the shape builder tool.
      • Preview of shape operations from context menu.
      • Importing Lab colors from ACB color palettes.
      • Using fills in pencil and pen tools to be enabled by default.
      • Undo and redo after using destructive color filters on selections with images.
      • Decreasing brush size with the keyboard should update the context panel.
      • Color palette panel scrollbar.
      • Swapping fill and stroke style using Shift-X, when no object is selected.
      • Use last selected document units when importing from files with no document units selected.
      • Restoring maximized VS view with Windows taskbar on top.
      • Drag and drop from Layers panel on Windows, using tablet devices.
      • Ruler cursor indicator should not flicker on Windows.
      • Context menu display on Windows did not update highlight correctly.
      VectorStylerV BoldlineB 2 Replies Last reply Reply Quote 7
      • J Offline
        Jayanta Das
        Container of tools in toolbar is gone.
        Mac Mini M4 Pro | 24Gb
        WIndows 11 | Intel i5 11Gen
        Wacom Intuos Pro
          VectorStyler @Jayanta Das
          @Jayanta-Das said in update 1.1.062:
          Not sure what you are referring to. The current selection info from the context panel is gone of course.
          Is there anything else missing? Maybe a screenshot of the previous version with highlightigh the tools that are missing would help.
            VectorStyler @VectorStyler
            One regression I just found: transforming or applying shape effects on gradient meshes is not working correctly. Fix will be available ASAP.
            • J Offline
              Jayanta Das @VectorStyler
              @VectorStyler I mean the bounding box of the icon
              Wacom Intuos Pro
                Yes, those are gone. There will be a gradual updating of the UI style, mostly after 1.2.
                J BoldlineB IngolfI 3 Replies Last reply Reply Quote 1
                • J Offline
                  @VectorStyler I kinda like it as without the bounding box the icons looks much sharper.
                  Wacom Intuos Pro
                    @VectorStyler Thank you for another impressive list of improvements and fixes to VS. I don't know how you fit all of this work into your day and still find the time to work on the 1.2 update behind the scenes. VS becomes more impressive and easier to use with every update. We appreciate you
                      @VectorStyler said in update 1.1.062:
                      I like the gradual approach as it gives everyone a chance to test things out and see if they like the new look. it also helps so we don't get confused by the layout if everything was changed at one time.
                      • IngolfI Offline
                        Ingolf @VectorStyler
                        Thanks! Looks MUCH better without those hazy bounding boxes.
                        🍏 macOS Sequoia Apple Silicon
