update 1.1.064
VectorStyler 1.1.064 release notes
- Snapping when repositioning shape drawing with the space key.
- Closing path with the Pen tool when the Adjustments option is disabled.
- Crash when using the pasteboard with the Select After Delete option enabled.
- Eraser tool deleted entire shape in some cases.
- Do not open multiple groups at once in layers panel.
- Show cursor when clicking in the empty search box.
- Guideline snapping to path nodes.
- Fixed regression in scaled text highlight and cursor display.
- Multiple node selection from a single object should not align to the artboard by default.
- Using the style picker tool while in isolation mode.
- Expand stroke on objects inside groups.
- Zoom, view rotate and pan tools to not show context menu.
- Undoing a mesh skewing did not refresh correctly.
- Double clicking on a mesh edge to add a new mesh node at the correct position.
- Added document option to show coordinates relative to artboard.
