    update 1.1.068
    19 Posts 7 Posters 3.2k Views 6 Watching
      VectorStyler 1.1.068 release notes
      • Use correct PDF page size when importing multiple pages onto a single canvas.
      • Fixed tablet pressure handling on Windows.
      • Better closed path handling with Pen tool.
      • Creating artboard with click should consider current object selection.
      • Open multiple palettes with the open palette menu command.
      • Detecting contact point when hovering over edges of shapes inside groups.
      • Monochrome preview mode.
      • Refresh after union operation.
      • Expanding transformed text on path.
      • Changed user data location on Windows.
      • Reduce snap tolerance for rectangle side bending.
      b77B J H 3 Replies Last reply Reply Quote 4
      • b77B Offline
        b77 @VectorStyler
        Thanks! Can there be a more direct command in the View menu > Display for this also?
          Boldline @b77
          @b77 said in update 1.1.068:
          This is actually where I was expecting it to be. Where is it currently? I was looking for it to no avail
          F b77B 2 Replies Last reply Reply Quote 0
          • F Offline
            fde101 Global Moderator @Boldline
            @Boldline there is an icon for it along the right side of the main toolbar.
            • b77B Offline
              b77 @Boldline
              @Boldline It's in the View menu > Display > Display Options:
              • b77B Offline
                b77 @b77
                @fde101 is right — there is a direct button for Monochrome Preview mode in the context panel:
                Didn't see it because I have a custom icon arrangement.
                But I still think it should be included under View menu > Display. 🙂
                • IngolfI Offline
                  Ingolf
                  I also have a custom icon arrangement - and I can't add it from customize toolboxes on this Windows installation, can't find it, searching for Mono doesn't give me any results either.
                  Added Display options as a workaround for now.
                  🍏 macOS Sequoia Apple Silicon
                    Throwing my thoughts in the ring - I don't love the monotone option as a new button on the UI unless it was going to include a dropdown to swap to any of the other modes listed in the display options>mode section currently. Down the road, I could see this being useful as an option for people to add to their customized contextual or UI menus - those who want easy access to swap around their display options
                    It makes more sense to me to leave it in the display option panel and like @b77 suggested, View>Display>Monotone.
                    Its going to be otherwise confusing that it's included with all the other modes in the display options panel itself, but not as an icon in the UI or listed with the rest of them under View>Display>
                    0_1669850986927_8b2c901c-9b8c-499b-8a5c-979c7f28c43c-BLD 2022-11-30 at 18.29.37.png
                    • J Offline
                      Jayanta Das @VectorStyler
                      Import a two pages pdf in VS, First page shows blank.
                      Mac Mini M4 Pro | 24Gb
                      WIndows 11 | Intel i5 11Gen
                      Wacom Intuos Pro
                        VectorStyler @Jayanta Das
                        @Jayanta-Das said in update 1.1.068:
                        Send me this PDF file, I will try to replicate the problem.
                        • J Offline
                          @VectorStyler Sent
                          Wacom Intuos Pro
                            @VectorStyler Sent
                            Got it!
                            • H Offline
                              Harry @VectorStyler
                              @VectorStyler said in update 1.1.068:
                              Thanks for adding this!
                              Here are my 0,02$ to make you all happy 🙂
                              1. leaving display icons in main toolbar
                              2. adding "Monochrome" option to View/Display pop up menu as @Boldline suggested
                              3. adding "Monochrome" to other Display options in View/Customize/Keyboard Shortcuts/View:
                              BoldlineB VectorStylerV 2 Replies Last reply Reply Quote 2
                                Boldline @Harry
                                @VectorStyler I could see these options consolidated under one icon on the UI much like you did with the alignment and transform options
                                0_1670439054200_bde44fbe-9dd9-4bbb-b7a9-8fea4816c725-BLD 2022-12-07 at 13.49.06.png
                                  VectorStyler @Harry
                                  @Harry These will be fixed in the next build.
                                    @Boldline said in update 1.1.068:
                                    Would this one icon open a menu?
                                    • b77B Offline
                                      b77
                                      @VectorStyler Yes, it would open a menu. But there is no need for a special icon — just the one of the current preview mode will do.
                                      On the other hand, one button might prove limiting in the future, if one of the preview modes has additional options.
                                      So I'm not necessarily advising for one icon.
                                        Boldline @b77
                                        @b77 I agree it would not need a special icon - whatever is currently in use would be shown as active.
                                        How would that be different than the other options that are currently using one icon to represent a dropdown of options? If options are added, wouldn't it be a lot like what alignment panel offers?
                                        A lot of the options currently in the UI are either-or. you are either using monochrome, or pixel or vector view or you're not (unless you turn on the dual view) they take up a lot of space as they are currently.
                                        There's always the chance that things need to be adjusted later as new options or ideas are added. That said, we've had pixel view, vector view, outline mode for a long time and now monochrome view, and nothing has been added to them in terms of extra settings. The more immediate need is keeping the UI spacing clean, especially from rarely used settings
                                        • b77B Offline
                                          b77 @Boldline
                                          @Boldline I was thinking of a simple menu, not a panel, and what if one of the preview modes will get different options itself.
                                          But as they are now, things can be simplified.
