    How does arithmetic operations work in Transform panel?
    5 Posts 2 Posters 4.5k Views 2 Watching
    • H Offline
      Harry
      In Transform panel, basic arithmetic operations like +, -, *, /, for move, dimension or scaling doesn't work as expected.
      Skewing and rotating seem to work well.
      0_1669988637188_6dbc36e4-f0bc-4278-b4b6-9fbe652f0f1a-image.png in Transform panel
        VectorStyler @Harry
        @Harry The [mm] gets in the way. Delete [mm] and then add +10
        H 1 Reply Last reply Reply Quote 0
        • H Offline
          Harry @VectorStyler
          @VectorStyler said in How does arithmetic operations work in Transform panel?:
          Tried this already - when I delete [mm} and add +10 the result is in [meters]
          But your method works for scaling.
          P.S. Do we always have to delete units? For degrees like skewing and rotation basic arithmetic operations work well.
          • H Offline
            Harry @Harry
            @Harry said in How does arithmetic operations work in Transform panel?:
            I meant work well without deleting units
              VectorStyler @Harry
              @Harry In the angle editor the units are just decorative.
              In the position / size the units always convert to [pt] and this causes the issues here.
              I will try to improve this.
