    update 1.1.072
    11 Posts 6 Posters 1.6k Views 5 Watching
      VectorStyler 1.1.072 release notes
      • Exporting gradients to EPS files.
      • Text decorations editing in character modal view.
      • Rendering stripes on open outlines with overlapping start and end nodes.
      • Opening stroke color popover should not change color.
      • Expanding symbols with blend objects to create correct copies of blends.
      • Fixed glyph alternate selection.
      • Do not reset document display on every host settings change.
      • Layer thumbnail refreshing when objects are deleted or created.
      • Allow switching to temporary panning tool while the text tool is active.
      • Do not apply alignment after the spacing is changed in the Alignment panel.
      • Dragging guidelines with an artboard selected should add it to the artboard.
      • Window button hovering indicator.
      • Removing nodes when control points are also selected.
      • Fixed panel title double click on Windows.
      • Added command to select all objects inside a group.
      • Fixed crash when importing PDF with JPEG 2000 images.
      • Show correct style names for larger font families.
      • Also search for glyphs by Unicode name.
      • Add blend mode handling to opacity flattener.
      • Improved AI file format reading.
      • Fixed bug in SVG image reading.
      • Fixed SVG gradient reading.
      • Leave correct selection after combine operations.
      • Allow tracking for space characters also.
      • Clicking on opened fill popover button should not again.
      • Improved Windows menu behavior.
      • Notify on missing content links when opening documents.
      VectorStylerV IgullI 2 Replies Last reply Reply Quote 6
        VectorStyler @VectorStyler
        @VectorStyler There was an unnecessary notification about image files, when opening documents with embedded images. This is fixed now.
        Please download again if already updated to 1.1.072 as the version was not incremented for this.
        • b77B Offline
          b77 @VectorStyler
          @VectorStyler I downloaded the installer from https://www.vectorstyler.com/releaselog/, is that the latest?
          Asking because I just sent a bug report about relinking images, and it still happens after downloading the installer from /releases.
            VectorStyler @b77
            @b77 yes it is the latest. This is a different error. Will be fixed ASAP.
            • IgullI Offline
              Igull @VectorStyler
              @VectorStyler said in update 1.1.072:
              Definitely fixed, thanks. Also like the new (?) artboard per page rather than having layers - works well for me - even nicer than AI !
              Neil
                Subpath
                @VectorStyler, thanks for the update
                Found a regression, the Stroke Width Field in Context Panel
                seems broken, does not take a value
                Stroke Width in Appearence Panel and Stroke Panel works
                Here a Video
                VectorStylerV BoldlineB 2 Replies Last reply Reply Quote 1
                  Subpath
                  Have an additional question
                  Where should I mention regressions after an update ?
                  Better under bugs ?
                  Or here under the announcement of the update ?
                    VectorStyler @Subpath
                    @Subpath said in update 1.1.072:
                    Replicated.
                      @VectorStyler thank you for the awesome bug fix build update!
                      • IngolfI Offline
                        Ingolf @Subpath
                        Better under bugs ?
                        Always under bugs - a bug is a bug - for clarity, structure and to put it where everyone can see it, follow it etc. 🙂
                        Also better to keep a discussion and additional questions focus in a thread of its own.
                        🍏 macOS Sequoia Apple Silicon
                          Boldline @Subpath
                          Stroke Width in Appearance Panel and Stroke Panel works
                          Here a Video
                          can confirm the issue here as well
