    Corner tool possibilities
    7 Posts 2 Posters 6.5k Views 1 Watching
      I'm going to run a test and see how many of these can be accomplished in Vectorstyler with the corner tool
      https://www.instagram.com/reel/CnPR5N3J4rf/?igshid=Zjc2ZTc4Nzk=
        Subpath @Boldline
        @Boldline said in Corner tool possibilities:
        i would say all and many, many more 🙂
          The top row was pretty easy to replicate, but with the rest I was unable to figure out a way to replicate with just the corner tool like in the IG post. Is there a way to get a negative bend/sharp corner in the middle using the corner tool like in the second and third rows of the example video?
          0_1673796637611_e6d8aef9-d294-43d0-8864-3933803f415b-BLD 2023-01-15 at 10.24.49@2x.png
          Here was as far as I could go:
          0_1673796647397_7a4131f5-b6b0-4936-9395-02372915ffa4-BLD 2023-01-15 at 10.27.15.png
          In practicing with these, I noticed it is difficult to pull the specified corners to meet perfectly together
          Perhaps adding a slight magnetic snap when they cross over one another? much like what was added to the parametric shapes? If added, I'd make it more subtle than the current magnetic snapping setting for the parametric shapes (I'd even lower the power of the snap for the parametric shapes as well)
          Also noticed with the last shape I tried to make in the video above, there seems to be a strange result when it aligns overtop another point:
          0_1673798034829_85808540-d520-4e55-afaf-20fc732ec5d7-BLD 2023-01-15 at 10.53.44.png
            Subpath
            @Boldline
            First thank you, for making me take a second look
            on corner creation.
            Recommend to use the Corner Panel for precise settings
            you can change the Values in the Input field with the Scroll Wheel.
            I also recommend to take a look at "Corner Shapes" Video
            from Vectorstyler Tutorial Videos at Viemo
            Here the Link to the Video
            Pic from the video
            You get negative Corners if you set this two Icons
            in the Corner Panel.
            The Pic for negative Corner Settings in Corner Panel
              Boldline @Subpath
              @Subpath Thanks for your help as well. I had not played around enough with the settings in the corner panel prior to this.
              I was able to easily recreate all the shape samples in the IG video after your helpful post
              0_1673804737753_2ce412b2-221b-4d30-825d-d41e43979eda-BLD 2023-01-15 at 12.44.17.png
                Subpath @Boldline
                @Boldline
                your welcome, looks great
                so mission accomplished 🙂
                bwt for me the Corner Tool looks
                very promising for Pattern creation
                  Boldline @Subpath
                  @Subpath said in Corner tool possibilities:
                  Yes the immediate mission was accomplished! Hoping @VectorStyler can address the minor but important suggestion for improvement and the error with the top row far right example that seemed to overinflate
