    update 1.1.078
    10 Posts 5 Posters 1.8k Views 4 Watching
      VectorStyler 1.1.078 release notes
      • Fixed problem with transform copies and transform each on multiple selected objects.
      • Do not show corner handles in transform mode for small frames.
      • Importing and exporting registration colors to PDF.
      • Embedded PDF importing should not create global colors.
      • Fixed possible freeze when editing text.
      • Flattening transparency with blending modes and background.
      • Fixed problem with activating certain font types with FontBase.
      • Fixed the flipping option in grid repeater.
      • Allow editing nodes of hidden objects.
      • Updating snapping mode icon in context panel.
      • Allow drawing smooth nodes with the Pen tool quickly.
      • Do not show gird by default in new documents.
      • Fixed crash with certain color embedding modes.
      • Allow repeaters inside tiling pattern content.
      • Repeater intensity preview is fixed.
      • Changing offset path shape effect width profile.
      • Content of clipping path has wrong positions when clipped.
      • Allow selection actions to be added in Layers panel context menu.
      • Small margin shown in full screen mode on Windows.
      • Close All documents cannot be canceled.
      • Editing gradients with previous transformations.
      • Rotating certain gradient types did not rotate in correct direction.
      • Copy of a path section should paste at the same place.
      • Merging consecutive nodes should create correct control points.
      • Expanding appearance of a repeater object should remove hidden backdrop.
      • Fixed undo of certain expand appearance operations.
      • Do not allow pasting inside locked objects or layers.
      • Importing SVG shapes containing arcs.
      H BoldlineB IngolfI 3 Replies Last reply Reply Quote 6
      • H Offline
        Harry @VectorStyler
        @VectorStyler Thank you for the continuous development of VS!
        @VectorStyler said in update 1.1.078:
        It seems fixed now!
        J 1 Reply Last reply Reply Quote 1
        • J Offline
          Jayanta Das @Harry
          It seems fixed now!
          @Harry @VectorStyler It still shows gap in my pc. I also did fresh install VS.
          Mac Mini M4 Pro | 24Gb
          WIndows 11 | Intel i5 11Gen
          Wacom Intuos Pro
            @VectorStyler Thank you for your relentless hard work improving VS
            • H Offline
              Harry
              @Jayanta-Das I don't have a gap anymore.
                VectorStyler @Jayanta Das
                @Jayanta-Das said in update 1.1.078:
                Do you have autohide enabled for the task bar?
                • IngolfI Offline
                  Ingolf @VectorStyler
                  I don't see any improvement? 🙂
                  🍏 macOS Sequoia Apple Silicon
                  • J Offline
                    Jayanta Das @VectorStyler
                    @VectorStyler Yes
                    Wacom Intuos Pro
                      @Jayanta-Das When the task bar is in autohide mode, there a small gap to let the task bar reveal when the mouse is there.
                      I will try to find a better solution for this.
                        VectorStyler @Ingolf
                        @Ingolf I will keep this issue open and try to replicate it.
