update 1.1.085
VectorStyler 1.1.085 release notes
- Fixed bug in expand stroke.
- Changed the locked icon in the Layers panel.
- Allow spot color exporting into EPS and PDF files.
- Fixed crash when saving color palette into ACB format.
- Color palette names to be the file name.
- Do not allow negative profile in stroke width tool.
- Fixed regression when deleting a node of a path.
I don't know if the freezing of the Node Width Tool
should be fixed.On my first attempts it seems to be. But on later attempts,
I have some.
What is definitely back is the problem that I am almost unable
to place a Width Node near another and deselecting a Width Node.It works a little better when zooming a little further away from a curve
and tends not to work when zooming closer to a curve.Setting new Width Nodes in "Edit Profile" works best.
Here a Video
From my observations, it looks like something is slowing down the deselecting
of the Width Nodes. It is slow compared to deselecting regular Nodes -
@Subpath I don't think any of the changes in this build are supposed to fix
the Stroke Width occasional freezing. -
yes, think so too
but was unshure -
@Subpath The stroke freezing issue is still open, as I could not replicate it yet.
I looked through some recent changes and I will try to provide some fix in the next build. -
thanks for the info, was just a guess of mine
as always take your time, no need to rush
i use the "Edit Profil" for set a new Width Node
(Node Width Panel Menu)
as a workaround -
@VectorStyler said in update 1.1.085:
Excellent, shows up well against the unlocked icon
Might be even better than colour LOL
Neil
