    Alternative method to align objects
    4 Posts 3 Posters 5.1k Views 2 Watching
      This method of getting two objects to align perfectly looked interesting https://www.instagram.com/reel/Cs4CAynIZNo/?igshid=MmJiY2I4NDBkZg==
      VectorStylerV S 3 Replies Last reply Reply Quote 0
        @Boldline This moves the nodes not the objects, is it so?
          @Boldline This should be doable using the alignment panel. Select the node and then align to center in both vertical and horizontal directions.
            Subpath @Boldline
            @Boldline
            as i came from Coreldraw, which also has
            options for aligning nodes
            but I can say that VS is far more superior here 🙂
            can only recommend to experiment with it
