Option to copy document settings from another existing file
  • What about an option to copy the settings from an open document into the currently active one? So for example, with more than one document open, going into the "document settings" panel, there could be a dropdown to choose another open file to copy the settings from
  • @Boldline If arboards and their sizes are included in this, it could get complicated when
    dealing with documents with different arboard counts and sizes.
    It can help if you have two "real-world" documents to send to the developer, together
    with a more detailed explanation about what you need to have copied from one
    document to another — why copy these document properties but not those other.
    @Boldline I will find a way to do this, for the options that can be selected at setup.
    @b77 if multiple local artboards are created, those will not be copied.
