update 1.1.105
VectorStyler 1.1.105 release notes
- Fixed regression in Paste Inside.
- Grid repeater flipped mode flag to position objects correctly.
- Primary color mode in modal color editor to use current color mode.
- Converting text with corner to curves should retain the corner.
- Updating color from objects with no fill or style should keep the color mode.
- Keep mesh boundary shape when removing fill from a mesh object.
- Allow stroke attribute for mesh objects.
- Fixed stroke profile adjustment with transparency mask content (break apart may be needed for some shapes).
- Fixed cursor update issues on MacOS.
- Two or more node joining should be inactive for single node selections.
- Assign color style from the styles panel to stroke selected in the Appearance panel.
- Allow clicking inside shape for selection in composite shape selector mode.
- Paste to merge styles by name.
- Increased snap tolerance for rectangle bending.
- Opened workspaces to be listed in the menu (after restart also).
- Click on top of palette bar grid should still select color if inside the grid.
There is a new build up, fixing some issues that were still in the previous one.
Thanks @VectorStyler I appreciate the consistent updates and improvements to the program
@VectorStyler Nice!
can only repeate what @Boldline allready wrote
..appreciate the consistent updates and improvements to the program ..
I agree with everything that has been written above
@VectorStyler I understand that fixing the bugs is a priority but I thought - perhaps wrongly - that v1.2 would soon be available with a new/different user interface and new layout features. I'd be delighted, but is that indeed(/yet) the case or will it be much later? Just a question, as I've been waiting for this new UI before using VS again.
@VectorStyler Always appreciating the updates. This tool delivers update after update. Great work.
MacBlook Air: A1466 / macOS 10.15.7
MacBook Pro: A2799 / macOS 13.3
VS 1.1.107I feel that ver. 1.1.107 is a more stable version.
There were some twists and turns around color.
That seems to have been resolved.
There have been few bug reports, and I am about to start using it on the front line of my private production work.
Thanks for all your work. -
@861475_VctSt said in update 1.1.105:
Let me know if there are any issues still
