Keyboard Shortcut(s) Broken
Trying 1.2 beta out on my Mac M2 to stay away from my regular setup on my other Intel iMac -)
Wanting to regress the Line tool to the "L" key (from the VS default "\" key), I deleted the default and added the "L" in place. No matter if I restart VS, the Line Tool always shows as "\" in the toolbar and doesn't change - the Line tool always uses the \ key
I really wish I could simply have loaded my own carefully (and time consuming) selected settings from 1.1 :-(((((((((
Neil
@Igull Shortcut files should be loadable from 1.1
One thing to check, did it save a shortcut file in the user data folder?
Yes, saved a shortcuts.xml in NumericPath/Vectorstyler1.0/vector/data/resources.
Loaded a shortcuts file from v1 and that works just fine - I'm sure I read that you couldn't do that ?? :-))
Also loaded a toolbox file from v1 and that also works just fine - happy days
 Toolbox issue occurs if you do a Panels/Toolbox Style/Compact Toolbox- you end up with a default set and unless you have saved a set of your own, no way back.Neil
Cancel my last, the toolbox data that I had saved from v1 while looking very close, was NOT the same - pretty much a mish-mash of tools that I hadn't chosen
The shortcuts still seem to hold up 'though.
Neil
@Igull Looks like there is still one issue: the app needs a restart to have the shortcut show in the tool tip.
I opened a bug on this one.I will test the toolbox thing also, the problem is that 1.2 has a lot of new tools.
