    Is there a way to flatten blend groups and similar controlled constructions?
    11 Posts 3 Posters 12.1k Views 1 Watching
    • b77B Offline
      b77 @Arde
      @Arde Use 'Expand Blend' from the Effects menu > Blend.
      • A Offline
        Arde
        Great, thanks!
        • b77B Offline
          b77 @Arde
          @Arde Btw, if you want to modulate the spacing between the interpolated objects, you can do it from the Blend settings > Transfer: https://recordit.co/l2O7MVL0Cx
          A 1 Reply Last reply Reply Quote 0
          • A Offline
            Arde @b77
            @b77 Wow thanks. This app is so full of features that I was pretty sure that this was implemented somewhere, too, but had not noticed these controls yet.
            Update: Checked it now but I could not find a way to adjust distance between the objects using a curve -- I mean "acceleration" or "deceleration" so that if you have different size of intermediary shapes, you can use a curve to get the distance look right (e.g. even, or packed in either end). It seems the curves only adjust size and coloring of the shapes.
              VectorStyler @Arde
              @Arde In the Transfer field (of the Transfer tab) you can select to control the what shapes are adjusted (separately from the styles).
              Could this do the trick?
              • A Offline
                Arde @VectorStyler
                @vectoradmin said in Is there a way to flatten blend groups and similar controlled constructions?:
                I just probably fail to see the feature but to me it seems that I can only choose Style (coloring) or Shape (size), or both, from the Transfer drop-down list. Or can I also control the distance (acceleration/deceleration) of the objects, similarly as e.g. in CorelDRAW (where "Object" refers to distance rather than the size of the objects, see below):
                  VectorStyler @Arde
                  @Arde Shape controls both the distance and the size. I will open an issue to have a distance control also (will have to look into how that works).
                  • A Offline
                    Arde @VectorStyler
                    Ok, thanks. It may be that I just could not use it but I failed to adjust the spacing of that simple graphic above similarly as it is done in CorelDRAW. It is great if distance can be an additional curve. I think that size cannot be adjusted in CorelDRAW (at least in v.2017 which I used above) so that the size is there determined only by the start and end objects and intrapolated from them. If size can be determined by a curve, it is likely that there is also need for a separate distance control.
                      VectorStyler @Arde
                      @Arde @b77 The new build adds a separate "Position" function to the blend object transfer curve options. This will control the position of the inner objects.
                      • A Offline
                        Arde
                        Brilliant! It is very rewarding to give feedback when suggestions and reported bugs are clearly noted and reach immediately developers!
