    Tapping "L" key twice to convert a selected node to a cusp is also switching me to the path sketch tool
    7 Posts 3 Posters 8.2k Views 2 Watching
      Tapping "L" key twice to convert a selected node to a cusp is also switching me to the path sketch tool as both are activated with the "L" key
      We had this problem before a while back. Did it get fixed and then broken again? Or did I need to edit a setting?
        @Boldline Yes, this is a default shortcut assignment problem. I will try to find a solution for this.
          @VectorStyler I'm certainly not a developer, but is this not just an issue with VS not allowing enough time for the second tap of the "L" to register?
            @Boldline said in Tapping "L" key twice to convert a selected node to a cusp is also switching me to the path sketch tool:
            I think the issue here is that after the first L the node is converted, the second L fails (nothing to do) and there is a fallback to the default shortcut.
            I will try to fix this for the next build.
              @VectorStyler This will be a good fix all around because if we can successfully add double clicks to certain tools, that increases the once-limited number of keyboard shortcuts beyond what 2 or 3 keyboard combos can offer
              • b77B Offline
                b77 @Boldline
                @VectorStyler Here pressing L the second time retracts the node handles "under" the node.
                No switching to the Path Sketch tool…
                  VectorStyler @b77
                  @b77 said in Tapping "L" key twice to convert a selected node to a cusp is also switching me to the path sketch tool:
                  I have to replicate this.
