    Convert Text to ...
    2 Posts 2 Posters 3.0k Views 2 Watching
    • AyoA Offline
      Ayo
      The menu command to change between shape or frame text now says: Convert Text.
      Convert to what? Image, paths, numbers, lower case, braille, code etc....
      Isn't this a bit unclear?
      • If text is frame text > Convert to Shape Text
      • If text is point text > Convert to Frame Text
      (one of the two greyed out) would be better.
      This counts two lines of text instead of one but clarity takes what it needs.
      Ctrl-V can technically remain as a single toggle, right?
      VectorStylerV 1 Reply Last reply Reply Quote 3
        VectorStyler @Ayo
        @Ayo said in Convert Text to ...:
        Convert to what?
        It converts between shape and frame text. I will add a better (automatic) naming based on the selection.
