    Transform (rotate) in Text Editor reference point
    6 Posts 2 Posters 5.7k Views 2 Watching
    • AyoA Offline
      Ayo
      1. Checking the 'Transform in Text Editor' ON setting. Reference point (center of rotation) for rotation is very, very far away. Shouldn't that be the center of the object?
      2. Switching tools makes text uneditable. Need to put 'linked contend' in Transform Tool again.
        https://recordit.co/UaFAMBlPkD
        VectorStyler @Ayo
        @Ayo I could not replicate either of these points with a simple test. Send me a file where this occurs.
        AyoA 1 Reply Last reply Reply Quote 0
        • AyoA Offline
          Ayo @VectorStyler
          Think I found it!
          Transform takes place outside the artboard.
          Should that be a problem? Often work this way to prepare semi-finished products that ultimately find their final place on the arboard in the drawing/layout.
            VectorStyler @Ayo
            @Ayo said in Transform (rotate) in Text Editor reference point:
            This should not be a problem.
            I got the file and tested it, and indeed there is some issue. There is a lot of "empty" text inside that frame with formatting.
            How was the text in that frame created?
            • AyoA Offline
              Ayo @VectorStyler
              @VectorStyler said in Transform (rotate) in Text Editor reference point:
              Good to hear.
              Created by just dragging a text rectangle and copy/paste from webpage into frame. When I turn on invisible characters I only see 7 blank lines/paragraphs.
              Had some trouble gaining access and had to mess around with Linked Content several times to get the cursor happily blinking again.
                VectorStyler @Ayo
                There might be something here. I have to replicate this.
