    Artboard Label Settings
    6 Posts 4 Posters 6.1k Views 3 Watching
    • AyoA Offline
      Ayo
      While checking out the 004 beta Artboard alignment bug fix
      I stumbled across the following issue.
      b77B VectorStylerV 2 Replies Last reply Reply Quote 1
      • b77B Offline
        b77 @Ayo
        @Ayo Displaying some of the settings directly and using a 'More…' button for the rest
        would not mess with the height of the Settings window or need scrolling bars:
          VectorStyler @Ayo
          @Ayo I added this to the backlog. I think it would be better to not use more than one line for this. The size of the settings view should be kept under control.
          AyoA 1 Reply Last reply Reply Quote 0
          • AyoA Offline
            Ayo @VectorStyler
            That's also good, but something is not right/needs to be done. In that case, a solution like b77 suggests is also an excellent solution.
            NB
            Size of the settings view is sometimes a bit tight for the extensive settings that VS offers.
              VectorStyler @Ayo
              @Ayo said in Artboard Label Settings:
              yes, this view was much larger in 1.1 (and it had the tendency of growing as things were added).
              But then some users could not use that on their laptop screen 😞
              So I instead created more sections, which can be added in the future also if needed.
              • F Offline
                fde101 Global Moderator
                Suggest putting the options in tabs on the right side - "Sizing", "Appearance", "Artboard Label", "Slice Label" perhaps?
                As long as there are only a few, logically organized tabs in a section that is still a logical and accessible way to organize these.
                Just need to be careful that it doesn't get out of control and lead to one of the three cardinal sins of tabbing: scrolling tabs, multiple rows of tabs or tabs within tabs.
