    When selecting only one corner for chamfering
    6 Posts 2 Posters 6.7k Views 2 Watching
    • L Offline
      Li Xiao
      Selecting only one corner produces the same result as selecting all corners.
      https://youtu.be/_X4toetvwc4
      The cause has been identified: the issues are caused by SpotOnTheMouse.
        VectorStyler @Li Xiao
        @Li-Xiao If the corner knob has a (thin) red outline around it, then it is selected.
        Click on an empty area to deselect all knobs, and select again what is needed.
        L 2 Replies Last reply Reply Quote 0
        • L Offline
          Li Xiao @VectorStyler
          @VectorStyler I use the chamfering feature very frequently, and I didn't experience this issue before. I tested it on three computers, and two of them had the issue while one worked fine. Even after restoring defaults on the problematic computers, the issue persisted.
          • L Offline
            @VectorStyler On the problematic computer, I uninstalled the program, deleted all related files, and then reinstalled the program, but the issue persisted. Then, I tried copying the configuration files from the computer that didn't have any issues to the problematic computer, but the issue still remained.
              @Li-Xiao I assume these are all the same versions. This could be related to how the mouse input gets to the app.
              I will try to find out what happens here.
              When you deselect all corner nodes, and select new ones, is the red circles change around the nodes?
              • L Offline
                @VectorStyler Thank you very much. It turns out that the issue is related to a mouse program called SpotOnTheMouse. The computer that didn't have any issues didn't have SpotOnTheMouse running, while the two problematic computers had SpotOnTheMouse running. After quitting SpotOnTheMouse, everything works fine. I purchased SpotOnTheMouse to record keyboard and mouse actions during screen recording, but I didn't anticipate this issue during testing.
