Decimal Width of 0 - On Screen Dimensions
 The dimensions shown on screen when objects are being moved are very difficult to read. This is especially the case when the distance is small, causing the text and indicators to overlap. Two changes would help. The color of the text; the best color depends, of course, on that you are working on. The second would be to eliminate the decimal portion. I had hoped setting the Decimal Width to 0 for pixels and points was a solution. In fact, I would prefer to have the Decimal Width at 0 in the panels as well. However, the Width cannot be set for pixels and the minimum for points is 1. My primary request, then, is to be able to set the Decimal Width to 0 for both pixels and points.
 @DMBrown said in Decimal Width of 0 - On Screen Dimensions: My primary request, then, is to be able to set the Decimal Width to 0 for both pixels and points. Added this to the backlog, will try to have it in the next build
