    Strange issue with Blend
    4 Posts 2 Posters 4.3k Views 2 Watching
    • L Online
      Li Xiao
      The "Smooth" option is not effective when selecting Steps. It works when generated in an older version and then modified with the current version, but there are issues with movement or other operations.
      0_1706533732417_Blend test.vstyler
      https://youtu.be/Z29c9AFgpPI
        VectorStyler @Li Xiao
        @Li-Xiao Clearly a bug, and can be replicated here also. I will try to fix this for the next build.
        • L Online
          Li Xiao @VectorStyler
          @VectorStyler Additionally, there is another issue where sometimes a few of pentagon appears in during hexagon blending.
          0_1706549255723_Blend test 2.vstyler
          https://youtu.be/BGoEhXa9xME
            @Li-Xiao said in Strange issue with Blend:
            Yes, this is a bug. It is caused by enabling the Blend Shapes option.
            A workaround for the other blend bug (when moving) is to use Control+R (Refresh) to reset the blend.
