Corrupted files after exporting / pasting
• At times when exporting artwork with transparency effects to jpg / tiff using a specified resolution of over 300dpi (let's say 400dpi), I am encountering undesirable results. This also occasionally occurs when exporting to pdf.
• Occasionally VS will export a blank white page unless you choose 'Selected Objects'.
• Another inconvinience also arises when I copy and paste the artwork into another document: A pop-up message is generated indicating that some content links are missing and you are then forced to relink.
• Sometimes even the swatches are corrupted after the copy and paste process.
Please note that I used the default settings on this example file.
The issue remains unresolved in VS 1.2.0.23.
Refer to attached files.
0_1714834773688_weatlea_shalom_door sign.vstyler
0_1714834824564_Result after copying & pasting into another document.vstyler
@William-Kansepa I opened a bug on this.
@William-Kansepa said in Corrupted files after exporting / pasting:
VS 1.2.024
Exporting artboard at 300dpi is working, but at 400dpi the previous challenge still persists. Artboard dimensions are 80cm H 50cm W. Even having removed the transparency effect from the images, VS generates a plain white jpg/tiff image after exporting at 400dpi.@William-Kansepa said in Corrupted files after exporting / pasting:
VS 1.2.024
Copy and paste is now working as expected. The pop-up is no longer coming up.
@VectorStyler thank you!Please note that in all instances I used the default settings for the testing.
I will try to replicate this.
