    update 1.2.052
    3 Posts 3 Posters 2.8k Views 3 Watching
      VectorStyler 1.2.052 release notes
      • Fixed a regression in clipped group expanding.
      • Fixed a bug in OpenType contextual substitution and position handling.
      • Added a new path blending mode (for Blend effect), suitable for aligning and blending open paths.
      • Tablet stylus will not retain brush style by default.
      • Added tablet stylus pressure control curve option (in tool options accessed with double click).
      • Fixed a crash when exporting slices from iconified panel.
      • Fixed the cursor size and position of empty distorted text.
      • Default snapping options of a new document to be the last selected options.
      • Fixed an editing preview issue with the node editor in outline preview mode.
      • Show grid margins option of the palette panel is global now for all color palette panels.
      • List tiling pattern content presets with pattern styles.
      • Default noise position to be relative mode in effects and brushes.
      • Fill style shortcuts to work for outline mode also.
      • Improved number field scrolling in Appearance panel.
      • Number field slider to align with the knob.
      • Changed the Arrange Artboards view layout.
      • Shape combination operations of the Path panel to be active for single groups also.
      • Improved crossing gap handling for composite paths.
      • Better default options selection in Stroke and Brush panels.
      1 Reply Last reply Reply Quote 11
      • C Offline
        creative
        Thank you for the quick fix of the tablet stylus pressure sensitivity and the addition of the pressure control curve option.
        • debraspicherD Offline
          debraspicher
          Thank you @VectorStyler, as always ❤
          32GB RAM @ 6000MHz
          PNY NVIDIA RTX 5070 Ti 16GB; Display 1: 4K @150%; Display 2: 4K @150%
