update 1.2.068
VectorStyler 1.2.068 release notes
- Fixed issues related to UI scaling.
- Improvements to Appearance panel.
- Fixed issues in contour fill selection.
- Do not select control points with box selection.
- Improvements in the Offset Path tool and overlay shape mode.
- Remove extension control points when retracting control points.
- Persistent blend steps after restart.
- Improved text frame resizing with double click to fit frame to text.
- Fixed a bug in Offset Path shape effect editing.
- Fixed an error with popup lists on scaled displays.
- Fixed a crash when using the add node action inside repeaters.
- Fixed OpenType color font rendering and contextual ligature issues.
- Fixed a bug in creating blends between mesh fills.
Thank you for this, as always!
