    update 1.2.073
    3 Posts 3 Posters 1.7k Views 3 Watching
      VectorStyler 1.2.073 release notes
      • Allow blending solid colors with gradients in the blend effect.
      • Fixed a bug in copying gradient fills through clipboard to other applications.
      • Drawing new ellipses should start with default options.
      • Disable corner options if ellipse is not an arc.
      • Fixed a bug in ungrouping transformed reference shapes.
      • Allow direct preview editing in wireframe mode also.
      • Added a new action to select objects with the same name (Select By Style -> Object Name).
      • Improved transform each mode for scaling.
      • Selecting parent when node is selected should select the object.
      • Allow content scaling in circular repeater.
      • Improved AI file format compatibility for gradients.
      • Allow center change in the Node Bump effect.
      • Fixed the randomized mode of the Node Bump effect.
      • Move curve segment when end nodes are selected.
      • Fixed a bug in the extend path tool when working with paths with rounded corner.
      IngolfI 1 Reply Last reply Reply Quote 9
      • IngolfI Offline
        Ingolf @VectorStyler
        @VectorStyler said in update 1.2.073:
        Fixed, thx.
        Fixed, thx.
        Works great, thx!
        🍏 macOS Sequoia Apple Silicon
          Subpath
          thanks, works much better now
