    update 1.2.080
    8 Posts 2 Posters 2.1k Views 2 Watching
      VectorStyler 1.2.080 release notes
      • Alternate tool to return to deep select tool if it was active
      • Fixed an error in undoing blend effects
      • Fixed an error in duplicating with the flip action from the context panel
      • Option to disable color palette name editing
      • Improved speed of some repeater types
      • Improvements for the proportional mode in the transform tool
      • Fixed a bug in noise fill previewing
      • Improved PDF importing
      • Fixed a bug in copy / pasting spot CMYK colors to another document
      • Decreasing the mesh distortion grid size should keep the existing mesh
      • Allow direct previewing in the path simplify tool
      • Fixed a crash caused by an OpenType font
      • Restored quadratic segment drawing mode using the Option(Alt) key
      • Fixed a regression with the crossing stroke option
      B 1 Reply Last reply Reply Quote 4
      • B Offline
        B-Vs-V @VectorStyler
        @VectorStyler Issue on W11 for me. The install seems ok but VS doesn't launch (update or repair) . I suppose I have to remove VS and reinstall again ?
          VectorStyler @B-Vs-V
          @B-Vs-V try removing and reinstalling.
          • B Offline
            @VectorStyler Not ok...
              @B-Vs-V After uninstalling, remove all VectorStyler folder from Program Files \ NumericPath
                VectorStyler @VectorStyler
                @VectorStyler Another thing: after doing a clean install, go to the Program Files \ NumericPath folder and compress the whole VectorStyler1.2 folder. Send that to me by email, so I can check which part did not install correctly.
                Also: there could be issues with the user data content (should not be), so you can try backing that up and removing it.
                • B Offline
                  @VectorStyler There was no folder after uninstalling VS. I've sent you the crashlog files I did find.
                    There is a regression on Windows with the Glyphs panel causing the crash. I will try to upload a fix ASAP.
