    Alignment to Shape/Path
    2 Posts 2 Posters 461 Views 2 Watching
    • F Offline
      FastVector
      First of all thanks for all the work you have done for 1.3. Really like the discovering of all the new features and tools. Especially the drawing tools 🙂
      When I started with the Align to Path Tool I expected when I would use Align to Shape from the Align Panel I could use the Tool. But it didn't, after a while I discovered that it only would work if I would use Align Object to Path out of the Object menu.
      If it is possible then I would like to see that the Align to Path Tool will also work when you've used the the Align to Shape out of the Align Panel.
      Windows 10 | 1920x1080 | 125%
        VectorStyler @FastVector
        @FastVector said in Alignment to Shape/Path:
        This would only work as an option of the Alignment panel, to create a "live" alignment group.
        Currently the "Align to Shape" from the panel will change the object position and rotation, but the result will not be a "live" effect.
        I will open a new feature for this.
