    Is there a way to add one or more objects to an existing mirror/symmetry group?
    7 Posts 3 Posters 770 Views 2 Watching
      Subpath
      @VectorStyler this is just a question.
      I've found/developed a way to do this. However, I'd like to know
      if you've already integrated such a feature, or what your solution
      would look like?
        VectorStyler @Subpath
        @Subpath Layers panel, drag objects into the mirror group.
        Or: double click to isolate, and draw / paste inside
          Subpath @VectorStyler
          ok, both doesnt work
          Objects are not displayed and not repeated
          Here a video
            @Subpath because a single object was repeated, not a group of objects. You have to start out with a group.
            S W 2 Replies Last reply Reply Quote 1
              got it and it works this way
              But not with a single object from the beginning.
              That seems a bit curious to me.
              Okay, thank you so much so far. I'll experiment with it a bit
              first and maybe get back to you later with more questions.
              • W Online
                William Kansepa @VectorStyler
                @VectorStyler said in Is there a way to add one or more objects to an existing mirror/symmetry group?:
                Perhaps this challenge could be overcome by revisiting how groups are made in VectorStyler? For instance creating a group from a single object (like how it's done in other software e.g. Illustrator and Affinity)? This group of one object is very convenient in many instances when designing.
                For example, in Affinity, you can apply a linear transparency effect to more than one side only.
                • Create a single rectangle
                • Using the Transparency Tool, apply a linear transparency
                • Group the rectangle
                • Apply a linear transparency to another side (this time the transparency is now being applied to the group)
                • Even after this you can still keep on creating more group levels from this single object and apply effects as required
                It's even possible to add more objects to this group(s) if you edit in the isolation mode.
                Note that all the effects disappear when you ungroup.
                S 1 Reply Last reply Reply Quote 3
                  Subpath @William Kansepa
                  @William-Kansepa , interesting
                  I don't see a big problem with that, since it's always easy to
                  use a kind of dummy group (without colors).
                  Or to plan a bit in advance. Alternatively, it is always possible
                  to use multiple mirror groups.
                  By the way, one way I found to add more objects to a mirrored single
                  object works by first creating a Symbol of it.
                  Then you use that Symbol and mirror it. Afterward, you can replace that
                  Symbol with any objects or add more by selecting the objects and using
                  the "Replace Symbol with Selected Object" button in the Symbols panel.
