    Up&Down arrows behaviour
    3 Posts 3 Posters 497 Views 3 Watching
    • M Offline
      marce
      Hi1 I see that in the input values fields that have up and up arrows, when you press them, you dont change the value, instead of it you popup a slider. So, you need to move your mouse again and slide to the desired value. Would be cool that the arrows would let you input the value directly, instead of having a second movement to do, to get the value you want.
      Memory 48gb ddr4
      NVMe CT100p 1TB
        VectorStyler @marce
        @marce This depends on the input field type: there are three kinds, no scroll, tiny scroll and slider.
        Sliders are used in fields with smaller or well defined range.
        • E Offline
          EricP
          @marce said in Up&Down arrows behaviour:
          Personally, I like to scroll values up or down by clicking on the field name and moving the mouse up or down. Very efficient. It avoids having to move your mouse to fetch the slider ball. Works on most fields (except ones with 2 input fields)
