• update 1.2.051
    13 Votes
    Will look into this soon. Thank you very much!
  • update 1.2.050
    9 Votes
    @VectorStyler But this operates with different effects. The father of the node is not the path. It has been cancelled. It needs to be verified on your side.
  • update 1.2.049
    @MWK Is this from the releases page? EDIT: found the error!
  • update 1.2.047
    5 Votes
  • update 1.2.046
    8 Votes
    @VectorStyler Impressive work! We appreciate your hard work and passion for the VS project
  • update 1.2.045
  • update 1.2.044
    5 Votes
    @VectorStyler File is send
  • update 1.2.043
    11 Votes
    @Boldline Holding Command+ while in the color picker tool should activate the transform tool.
  • update 1.2.042
    9 Votes
    Much nicer! [image: 1728147618741-d557320d-0f36-449a-8e81-d032c0581446-bld-2024-10-05-at-12.59.54.png]
  • update 1.2.040
    9 Votes
    So much progress per update and already see a lot of things I need to try/recheck. It's nice to see that our bug reports matter. You're doing a really good job here, @VectorStyler (as always)
  • update 1.2.039
    9 Votes
    @VectorStyler Ok, I see it now. It didn't seem to do this before, but it's possible I was only using the menu mostly after having trouble with nodes due to the poor scale. I had a lot of trouble with embedded control handles until you fixed scaling, so thank you for this. Now I mostly just rely on the keyboard shortcuts as I learn them.
  • update 1.2.038
    6 Votes
    @Boldline said in update 1.2.038: Added an option to render vector brushes as images. The vector brushes use the bend shape distortion to stretch vectors along a shape. This also works for images when the Distort Images is enabled. But, in some cases when the whole brush is an image (as in Affinity), it can be better to use the image distortion (instead of shape) effect for this. This will also distort gradients as an image.
  • update 1.2.037
    8 Votes
    @VectorStyler I did peak at Event Viewer and didn't see any errors or odd messages: [image: 1724533828673-31b69ce3-8cad-4f39-86c0-ccb9db35bcd9-image-resized.png]
  • update 1.2.036
    11 Votes
    @VectorStyler Great list of updates for VS! Text on a path movement is much improved and duplication on the path is a very helpful addition.
  • update 1.2.035
    7 Votes
    Thank you for this
  • update 1.2.034
    10 Votes
    Thanks again for the continuous updates.
  • update 1.2.033
    9 Votes
    After Hurricane Beryl’s destruction, climate scientists fear for what’s next I guess humanity's next move in this regard will be luxury prepper kits.
  • update 1.2.032
    11 Votes
    @VectorStyler Thank you for getting these updates out so quickly. No doubt you were probably ready for a short reprieve from eliminating bugs after uploading the recent build, but you got right on the vital fix that affects daily use and then even addressed a number of other bug fixes as well.
  • update 1.2.031
    11 Votes
    @William-Kansepa said in update 1.2.031: However, this new method will not work if you have 'Select Highlighted' active That is true, this needs the separate selection mode. But maybe then using two Layers panels might help.
  • update 1.2.030
    11 Votes
    @VectorStyler Keep up the great work! I appreciate the consistent updates and improvements to VS
