• update 1.2.029
    9 Votes
    @VectorStyler As an added bonus, my taskbar pin survived the upgrade. It's still orange, but it didn't create duplicate entries in Programs and Features this time.
  • update 1.2.028
    11 Votes
    @debraspicher said in update 1.2.028: This is the window it gives me when I try to open the program through Search or when I run repair install from Programs and Features. No idea why it says "network resource"... [image: 1718035444841-60d6d9cc-411f-4a70-a7ee-45cca598e662-image.png] I believe I have seen this years ago - diffent program, same issue. If the installation files (often a .msi file) have been removed or moved from their original location, Windows cannot find them to perform the repair. The network resource part is just misleading. As I remember, .msi packages are particularly sensitive to this issue for a few reasons because they store the installation path in the Windows registry or a installation log. If the installation file is moved or deleted, repair or changes to the installation will fail because the system looks for the file in its original location. .msi files are - I believe - designed for corporate setups due to their centralized administration, automation capabilities, security, and maintenance features. Anyway, that's how I remember it. As I mentioned, I have fled from Windows after 30 years of use, and I haven't missed Windows and these time-consuming, unnecessary problems for a second. Serif took it a step further into the abyss with the MSIX variation, which is a patch on a patch. Not recommended either.
  • update 1.2.027
    7 Votes
    @VectorStyler Thanks for the super quick response!
  • update 1.2.026
    7 Votes
    @861475_VctSt There was an inherent problem with the BTT configuration. Self resolved. Sorry for the trouble.
  • update 1.2.025
    10 Votes
  • update 1.2.024
    8 Votes
    @VectorStyler I can confirm that performance is much much improved...
  • update 1.2.022
    7 Votes
    Great - I'm not sure which regression, though.
  • update 1.2.020
    13 Votes
    @VectorStyler Great updates! I appreciate it
  • update 1.2.019
    11 Votes
    syllieS
    Thank you so much for all the hard work! I just cleared all my 'unread' posts and returned to find a ton waiting again, all marked as fixes for this release. Exciting to see so much work done, VS is getting better and better!
  • update 1.2.018
    8 Votes
    LoginErrorL
    Agreed. I feel inspired to write up bug and feature requests when I run into them, because I know they will actually get seen and worked on. I'm a software developer myself, so I know how valuable it can be to have testers who give good feedback, so I want to do my part to be part of that.
  • update 1.2.017
    @Jayanta-Das I tried to replicate this on Windows 10, but here the iconified panels can be resized to show icons only. I will try also on Windows 11.
  • update 1.1.123
  • update 1.1.122
  • update 1.1.120
    Uploaded a fix with the text resources issue.
  • update 1.1.119
    @Li-Xiao Thanks for reporting this, It should be fixed now.
  • update 1.1.118
    @Li-Xiao said in update 1.1.118: The Width Eraser Brush tool issue is not fixed, the tool options are not displayed when double-clicked Yes, one was left in 1.1 by mistake. Will be fixed.
  • update 1.1.117
    7 Votes
    Really glad to see so many bugs and requests of the last month already been fixed and implemented. Thank you for all the work!
  • update 1.1.116
  • update 1.1.115
    6 Votes
  • update 1.1.114
    5 Votes
