    Opening existing VS files in full main artboard view
    14 Posts 4 Posters 11.7k Views 3 Watching
      Here is an example of an existing VS file I opened just now. The light gray rectangle is the only artboard. I do not believe this was the last position I was in when I saved the file as most files open in this same position.
      I was wondering if it related to items positioned off the artboard, but there is stuff on either side
      here is a full screen shot of the same file after I zoomed out:
        @Boldline Currently, VS saves the last viewpoint of the file, so when opened next time (on the same screen) it should have the same viewpoint. Maybe an option could be added to have a "view all artboards" or "view last artboard" after opening?
          VectorStyler @Ingolf
          @Ingolf I'd like to know more about this "viewpoint" feature and how it could work best in VS?
            Ingolf @VectorStyler
            @vectoradmin said in Opening existing VS files in full main artboard view:
            The movie (ignore title)
            It think it would fit nicely into the navigation panel next to the zoom percentage. Similar to in AD.
            But please please with sugar on top, if you should ever add it, when adding a viewpoint the software should ask for a name immediately. I have to select rename just after creating viewpoints and other items in Affinity Designer. Every. Single. Time.
            And to avoid customers never finding it. I don't recommend hiding any of it in the panel menu. 🙂
              @Ingolf Added this to the backlog 🙂
                This would be a great addition to VS - the option to decide how you want files to open
                  Here the CorelDraw Way to save Views.
                  And CorelDraw assigns names automatically
                  to the views. No need to do this yourself.
                  Save Views in CorelDraw Video
                    Ingolf @Subpath
                    @Subpath But I need my own label for each viewpoint. Affinity also adds generic names automatically that I can't use for a thing later or now.
                    I need precise labels to know where the view takes me in a complex drawing. Many of these user interface choices are made from simple thinking, simple scenarios.
                    That dialog is full of percentages. That is designed by an engineer. I need info about what the viewpoints shows me, where it goes to. The percentage would never really matter to me.
                    @vectoradmin I would prefer that it behaved like when saving snapshots. Pop up with name suggestion (could be zoom percentage) - enter if user is okay with that name, and that would also mean consistant behavior across features. 🙂
                      Subpath @Ingolf
                      @Ingolf
                      In Corel it is no problem to rename your View
                      according to your needs.
                      I don't like the way via dropdown menus, to save a view.
                      Like in Affinity Designer.
                        Ingolf @Subpath
                        @Subpath said in Opening existing VS files in full main artboard view:
                        @Ingolf
                        I know, but I never use and never used the proposed generic name in AD or Corel so it is a problem for me that I have to rename every viewpoint I create.
                        When it pops up with a suggestion (like snapshots do already) it requires just hitting ENTER to accept it. Not a big deal and easy to figure out as a user.
                        Renaming is a additional proces that is breaks creating a viewpoint into two actions - the second requiring a lot more. It is simply bad UI design.
