    Fill transparency in appearance
    8 Posts 3 Posters 7.5k Views 3 Watching
    • J Do not disturb
      Jayanta Das
      After I change fill transparency of an object in appearance and make another object the new object retain the same transparency of the previous object, it doesnot reset value to 100%
      Mac Mini M4 Pro | 24Gb
      WIndows 11 | Intel i5 11Gen
      Wacom Intuos Pro
        b77 @Jayanta Das
        @Jayanta-Das This is by design — new objects adopt the basic properties of the last selected object (fill, stroke, opacity).
        If you need the opacity of new objects at 100%, modify it afterwards for the new object or select a fully opaque object before drawing.
        • J Do not disturb
          Jayanta Das @b77
          @b77 I know that. I am not taking about the opacity of the object, I am taking about the fill opacity of the object in appearance.
          Wacom Intuos Pro
            VectorStyler @Jayanta Das
            @Jayanta-Das The fill opacity is part of the fill attributes, and as such it is reused by the next object.
            • J Do not disturb
              Jayanta Das @VectorStyler
              @vectoradmin Is there any setting in preferences where I can make it reset whenever I make a new object? Object transparency carries the previous object's colour, stroke fill, but fill transparency in appearance is just like an effect apply to the particular object. It would be nice if it reset to default for new object like other program do. It will save some extra mouse click.😜
              Wacom Intuos Pro
                @Jayanta-Das I will add an option to reset the opacity of Fill and Stroke attributes for new elements. Added this to the backlog.
                • J Do not disturb
                  @vectoradmin said in Fill transparency in appearance:
                  Is this implemented?
                  Wacom Intuos Pro
                    @Jayanta-Das said in Fill transparency in appearance:
                    Is this implemented
                    Not yet. It is in the current feature backlog, features to be implemented for 1.2, more on this later 🙂
