Mesh gradient editor
Are you using VS on Windows or Mac? It seems that it could be some GPU config issue with the crashes.
About the gradients:
I tried to replicate the shape drawing after mesh gradient issue. At least in my case, after creating mesh gradients, new shapes are drawn with a solid fill.
As for the gradient crashes: try various options in the Preferences -> Performance -> Compute Engine.
@Devil-Dinosaur No such thing as burden
Great! this seems to identify the issue.
If you use Windows (?), you should also have the option for CUDA in the compute list.And: some OpenCL drivers may have issues, try to check if there is a driver update for the specific GPU.
@vectoradmin DD wrote in his first post that he uses a Mac with Sierra.
@Devil-Dinosaur You could include your computer's configuration in your signature (click your forum's icon in the upper right corner and choose 'Edit Profile'), so it's easier to figure out next time.
@b77 said in Mesh gradient editor:
Sorry! I forgot that.
I checked online and it seems that "metal" should be used instead of Open CL which cannot be upgraded on Mac. I set it to metal in preferences->performance and it works.
I add my signature.
Mesh gradient editor doesn't seem to work. clicking over line doesn't add horizontal or vertical line.
@Jayanta-Das When double clicking inside the mesh (but not on a line), it should add a new mesh node. Is that working?
I tested it and that part is working here.
Clicking on a line (edge) of the mesh is not working currently.
I will try to fix this ASAP. -
@vectoradmin yes clicking inside is working, but not on line.
@Jayanta-Das said in Mesh gradient editor:
Will fix that!
Doesnt work also on Win.
Only not on Line.
Double click inside the mesh work.
