Shape Builder not detecting consistently the intersections
As per title, I tried tons of variations of settings.. not working consistently.. sometimes it detects the intersection, sometimes not, maybe an option to set intersection tolerance ?
@abn5x The precisely touching shapes might be an issue.
Can you upload a vstyler file with the above figure?
@VectorStyler Sure, here you go!
@VectorStyler btw, the exact same shapes, do intersect correctly in Illustrator
Hi
I tried a little and it seems that it works,
if the space in the middle is not empty.I put a circle (could be any Shape i think)
in the middle and then it works here.
(win 10)
@Subpath Heya, it only works because the inner circle you created, makes intersection points, try making it a little bit bigger than where the tangents of the original circles are, and you'll see what I mean
I don't quite understand what you mean. I think the translation doesnt works so well.
English is not my first language. So a picture of what you mean might be helpful.But I can tell from my attempts that it doesn't work without the shape in the middle.
I guess you meant something like that
@Subpath The Shape Builder tool is supposed to create a shape from the two opposite circles and the empty space between all four without having to draw any other shape in the middle.
...The Shape Builder tool is supposed to create a shape from the two opposite circles and the empty space
between all four without having to draw any other shape in the middle....Thanks, @b77, that's how I understood the Shape Builder too, but I wasn't quite sure.
And I thought the find with this shape in the middle might be helpful for @VectorStyler to find the problem.
And in the meantime as a kind of workaround for users.
@abn5x The issue can be replicated here also. The problem is that some pairs of those circles are at a very small distance. If you set the stroke width to zero, and zoom in at where the shapes supposed to intersect, there is a very small gap.
Nevertheless, this should work, and I opened a bug to find a solution for these cases.
@VectorStyler Yeah, I know that there is some micro-space between some circle pairs, that's why I thought that by playing with the settings, I could make shape builder think there's an intersection in some tolerance range. But for my life I couldn't find any xD
@abn5x This is a bug (or more precisely a missing feature) of the shape builder. Will try to fix it.
@VectorStyler said in Shape Builder not detecting consistently the intersections:
I would just switch to Outline Mode (Cmd-Y) to check things like these.
