    update 1.1.042
    45 Posts 7 Posters 19.9k Views 5 Watching
      Subpath @VectorStyler
      That's cool Idea too!
      I imagined something like this a few days ago.
      But with the "Align to Shape/Curve" function.
      As you know, we can already align shapes to a shape/curve in the alignment Panel.
      So I thought it would be nice if these aligned shapes could then be converted into a pattern brush.
      But using Blend for this function is also great.
        VectorStyler @Subpath
        @Subpath said in update 1.1.042:
        Misunderstanding here: It is not about using blend for this, but about including blend inside a pattern brush 🙂
          I think I understood it the way you meant it.
          Just expressed myself a little clumsily here.
          • J Offline
            Jayanta Das
            Mac Mini M4 Pro | 24Gb
            WIndows 11 | Intel i5 11Gen
            Wacom Intuos Pro
              VectorStyler @Jayanta Das
              @Jayanta-Das The scrollbar in the Layers, Appearance (and some other) panels scrolls the list in those panels.
              The Stroke (and some other) panels have a fixed height.
              The common scrollbar is shown when multiple (vertically) docked panels do not fit, and this scrollbar scrolls the panel positions inside the dock.
                b77 @Subpath
                • Use transform tool as alternate mode in style and effect picker tools.
                @Subpath Thanks for suggesting it — good idea.
                On the Mac it's the ⌘ Command key that does this.
                  Subpath @b77
                  @b77 thanks for the info
                  will add your line in my Post above
                    Boldline @Subpath
                    @Subpath @b77 @VectorStyler I'm sure it's just me, but I'm not fully understanding the new feature of using the transform tool in connection with the shape effect tools. I appreciate that @Subpath brought attention to it and provided a cool video. Would someone be willing to elaborate further?
                    b77B S VectorStylerV 3 Replies Last reply Reply Quote 0
                      @Boldline It's mostly useful if you want to select (and maybe also transform) another object while using the Style or Shape Picker tools, without having to press V, select or transform then press the shortcut for the Picker tool again.
                      It's faster and similar to the way you can press Cmd (Mac) when in node editing mode (A) to temporarily switch to the Select/Transform tool, or vice-versa.
                        Subpath @Boldline
                        As @b77 already wrote, it speeds up the handling of the styler picker
                        and the Shape Picker tools a bit. Its a bit difficult to show it in a Video.
                        The old way of using these Tools still exists.
                        The usefulness of this alternative handling becomes more clear
                        when you use these Tools more often.
                        I will show a few possibilities of these Picker Tools in Tutorials.
                        But will take some time.
                        Here a very simple Example with a color blend
                        and its transfer to other shapes.
                        But these Picker Tools have many more uses.
                        Video see here:
                        Above the old way.
                        Below the alternate way with Ctrl now.
                        You see it in the Video.
                          @Boldline said in update 1.1.042:
                          This is used while in the style picker (or similar) tools. It was not yet added to the shape effect tools.
                            There were a few updates I did not understand based on the description. Would anyone be willing to elaborate more on these?
                            Copy, paste and select all shortcuts in MacOS save panel. (Not following this)
                            Added preferences option to disable direct scaling of shapes. (I was trying to find this in the preferences without luck)
                            Click drawing for 3 point circles. - (I know where this tool is but not understanding what was modified)
                            Click selection of overlapping nodes and objects. (what do we now do to access the overlapped node?)
                              I only know the answer to these two:
                              It's in Preferences > Editing Options 2 > Direct Shape Transformation.
                              When disabled, the Transform panel will reflect any size changes in percent (85%, 120%, etc) for the parametric shapes (smart shapes) and for text.
                              When enabled, smart shapes (parametric shapes unconverted to curves) will display at 100% when scaled and text as well when you change its size in pt.
                              It was difficult to draw 2-point circles with the 3-Point Circle tool — it was working only by click-and-drag and you had to press Escape before placing the second point to end the circle.
                              Now with only two clicks it's simple.
                              I guess it should be Cmd-C, Cmd-V and Cmd-A working in the Save or Save As panel, to copy the document name, paste text or select all text.
                              But it's not working here, so maybe it's something else?
                              LATER EDIT: It fails to work only on Monterey.
                              I guess this option is in Preferences > Document Editor > Click Through Node Selection, but I don't know how to make it work.
                                VectorStyler @b77
                                @b77 I tested the Save panel issue and it works here (have to test it on Monterey).
                                The overlapping node click-through works only for nodes in different objects.
                                BoldlineB Victor VectorV 2 Replies Last reply Reply Quote 0
                                  Blend in Pattern Brush works quite well so far.
                                  But it seems that when I like to change the colors with "Solid".
                                  The color I choose then is not taken for the middle part.
                                  Only for the starting and ending point
                                  see here
                                    Yes, this can be replicated. Added this to the backlog.
                                      Here some uses of:
                                      "Blend object inside pattern and other brush types"
                                      (It offers the possibility to use a blend inside a pattern brush)
                                      At first glance it appears somewhat unimpressive.
                                      But there is something in it 🙂
                                      How to create it:
                                      At first you need a simple Blend.
                                      Create two Shapes and create a Blend between them.
                                      Now select the whole thing and group it.
                                      In next step go to Styles and create a Pattern Brush preset from it.
                                      Select the Artistic Brush and paint a few strokes, choose one of them
                                      and select your previously created pattern brush to paint with it.
                                      Here a few uses i found so far.
                                      • use rigid shapes with scaling
                                        your shape will then be not deformed as you paint
                                        (its a pattern brush feature)
                                      • you could use colored Blends !
                                      • as some of you may know you could create multi Blends in VS
                                        but there some quirks with them as you would like to move them
                                        with the Shape Editor Tool
                                        ( but works if it is a Pattern Brush now )
                                        Video with simple Blend
                                        Video with multi Blend
                                        Finally "Big thanks" to @VectorStyler for that.
                                        @VectorStyler said in update 1.1.042:
                                        If I understand what the fix is supposed to do - I can copy text from another source and paste it into the file name section inside the save and the save-as panels. Testing this on the M1 mac with the newest build and for me, it's NOT working as it should. Nothing gets pasted.
                                        I tested it on the Intel computer in VS and that was successful
                                          @Boldline As I understand it, this doesn't work on Monterey, but it works on Big Sur and older.
                                            @b77 ok.. I have El Capitan on that intel machine so that makes sense.
                                            @VectorStyler mentioned it should be working on M1 macs and that has not been the case for me so far.
